Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Replacing LCD Lamp
Are there manuals on how to replace the lamp. I have a new lamp but don't know the procedure
    Sergeant:
  • 308 Answers
The lamp may not be the defective part as the ballast board has been known to cause problems with this model - Part#6913v00002c You didn't mention how long you have used the set, and I believe the lamp should last at least 4000 hours. The lamp is usually replaced by opening a door by taking out one or two screws in the back or side of the set.
Posted on Dec 29, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How can i fix my tv
Either lamp needs replacing or set needs reset. Try reset first; you can get reset procedure in owners manual. New lamp will cost $30 to $100 depending on where you purchase. Online search you can find out all you need to know about where to buy lamp and how to replace it. This model is easy lamp replace.
Aug 13, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
It overheats and pops the Xl-2100u lamp?
by pops? do you mean it explode? how many lamps? it could be the fan that supposed to be ventilating the lamp or it could be the the ballast, why the ballast because the ballast regulates the voltage in order the keep the lamp on, for ignition it sends around 15,000 volts after that it regulates the votage to a small amount of voltage around 5,000 so it could be sending the big amount of voltage all the time never regulates that or it could be regulating and then sending another big amount of voltage over and over until the lamp doesnt handle those changes.
Apr 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have hitachi 50v500 my screen went black and the lamp light comes on by the power button
Lamp light ON means TV needs new lamp as existing lamp is either broken or dead.
Replace lamp in TV, replacement procedure would be written in user manual.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture brightness is about 1/2 as it used to be what is the cause?
If its Sony KDF-E55A20 TV then it sounds that lamp in TV is getting weaker, time is coming to replace lamp.
New lamp will bright the picture again as it was before. Lamp replacement is easy and procedure is written in user manual.
Please buy Sony original lamp for your TV safety.
Thanks.
Nov 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Where is the lamp on Sony LCD Model No. KDF-E60A20 located in back of TV
There are two thumb screws at lower corners of TV, lose them and take off lower front panel of TV, there you will see lamp cover, unscrew and remove it, lamp is in front of you.
Lamp replacement procedure is written in user manual, click Sony Support to download user manual copy of KDF-E60A20 if required.
Oct 19, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
My sony wea lcd 60 inch television goes blank with no sound every 5 minutes or so for about 30 to 45 seconds then the picture and sound come back the set is just over 3 years old
Symptom shows TV needs new lamp and existing lamp is getting weak / dying.
Replace lamp in TV and procedure is written in user manual.
Let me know model number of TV if you need user manual copy.
Thanks.
Oct 02, 2009 | Sony Televison & Video
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Instruction on replacing a lamp bulb on Toshiba DLP 72hm196
Hi, when you order the new lamp it will come with install instructions in the box, if u have them and don`t understand them email me back and I`ll pull up a service manual, there all a little different so theres no one way fits all scenario, let me know, video-tek
Jun 05, 2009 | Toshiba 72HM196 72" Television
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
