Question about Jenn-Air 24 in. JDB8910 Built-in Dishwasher
Door spring on dishwasher broke
I have a Jenn-Air JDB8910AWW dishwasher and the door spring broke or disattached. Where can I get a new one(s) and can I put it on myself? I have a cabinet door-cover, which is heavier than the standard door. Do I need heavy-duty, (commercial), springs. It has been about six years since the dishwasher was installed by a professional.
  • 258 Answers
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
How do i fix my jenn-air refrigerator JSD2488DEB .The damper door and spring fell off while removing a part.I have no idea where the spring is placed?
Parts for Jenn Air JSD2488DEB Shelves Accessories Parts
This might help. However you could try putting the damper door in without the spring and moving it through its open and closing to see what is near the door the spring could hook to. Look for small holes or tabs.
Dec 31, 2014 | Jenn-Air Refrigerators
I took the inside of the door off my Jenn Air dishwasher and now it won't start
You broke it!!!!!!! Check out the wiring associated with on/off cycle. There might also be a switch by the door designed to not allow unit to turn on when door is open - check it out. It might not be engaged if the inner panel of door is not properly hitting the switch.
Aug 22, 2017 | Jenn-Air 24 in. JDB1100AWS Built-in...
Initially the soap dish had residual detergent (cascade packets) but now the detergent door won't open during cycle
probably needs a new spring. you can order a whole new door with spring easier, just search google for appliance parts
Jan 26, 2012 | Jenn-Air Dishwashers
Jenn-air quiet series Model JDB8910AWW Dishes seemed to wash OK, but did not rinse. There is water (soapy) in the bottom. What do I do?
It is likely the drain function did not work.
Empty the dishwasher and clean the filters at the bottom. You will need a small container to empty the water and also use a towel to soak the remaining water.
If cleaning the filters does not help then there may be a blockage in the drain hose (check the kitchen sink side also). You may want to also confirm if the drain pump is operating at the right time in the cycle.
you could refer to this diagram for the parts involved.
Good luck.
May 13, 2011 | Jenn-Air 24 in. JDB1100AW Built-in...
I have a Jenn aire jdb8910aww dishwasher and after every type of treatment and cleanser I still cannot get the powdery residue to go away. The only thing that works is white vinegar, but i have to use it...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 15, 2010 | Jenn-Air 24 in. JDB8910 Built-in...
How do you gain access to the Front Panel circut board? On a Jenn Air JDB8910AWW Dishwasher? If I want to check the soldering connections, I don't want to open up areas which would make more work for me....
the front panel control board is accessed by taking off the inside door panel that will release the control panel so you can get to the control board but do not try to solder connections on the board just replace the complete board
Apr 03, 2010 | Dishwashers
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Jul 26, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
400 people viewed this question
Top Jenn-Air Dishwashers Experts
Marvin
Marvin
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
