Question about ASUS I-A16C Sound Card
Had sound but not now and the input jacks are real loose
I did have sound up until 2 weeks ago and the input jacks to plug in speakers is real loose.I went to best buy and walmart and at best buy i was told that the sound card can't be replaced because it's built right in woud that be the case for a 4 or 5 year old computer
  • 837 Answers
Yes that is possible but if you have any pci slots left buy an inexpensive sound card adn install it and just disable the sound on the motherboard in the BIOS
Posted on Nov 23, 2008
My t.v display and sound will not turn on after the t.v has been turned on.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 21, 2012 | Vizio 32" E321mv 1080p 60 Hz Lcd Led Razor...
Cant figure out how to hook them up
Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
Jun 27, 2011 | Bose MediaMate Computer Speakers
Radio plays but plug in the rc jacks for the amp and subs and get this grounded out sound plug in different deck works perfect the deck worked fine a week ago
check for loose connections at your speakers and sub. If you have a loose connection, they can ground the other out... look closely for loose strands that may short it out. most of the amps have overload protection and cut out when there's a short/ground out issue..
I had this happen on my sub and it acted like the whole system was cutting out.
Nov 27, 2009 | Pioneer Car Audio & Video
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
The speakers sound goes in and out gets louder then softer sparatically
Check the jack on the input of the computer it sounds like a dirty or loose input
Mar 24, 2009 | Bose Companion 2 Computer Speakers
X-530 one speaker not working
this is a problem that i have faced as well it is likely that the cable going in to the jack could be loose and you might need to move it a bit, but in your case i think most likely would be that the input jack on the sub for the speaker is broken in that case you should call up logitech and ask technical support to see what they can do for you should be covered by warranty!
Feb 09, 2009 | Logitech X-530 5.1 Channel Speaker System...
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
ASUS I-A16C Sound Card Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
