Question about Myron & Davis AD273 Car Video Player
Audio I just bought a used suburban and it has this DVD player in it and the vidio works but I get no sound. How do I get sound to work. I have tried severl options and still nothing. I tried running through every radio station but it does not pick up anything.
  • 1126 Answers
SOURCE: We have a myron adn davis DVD player in our van.
Disconnect all power going to, battery power or DC/ Connector. Leave disconnected for 40Min., and it should reset back to normal.
Posted on Jan 17, 2011
0 characters
1 Points
Hi.. I bought a used vehicle(2010 Ford F 150) which has a farenheit dvd-36 system I tried to play the dvd and the monitor, wire, remote....everything is working good. but, the only problem is that the
OK....Pull the dvd player out. Look to see if it has speaker wires coming off the back. If not, does it have rca plugs???? (red and white). if so then you are gonna need an amplifier to get sound. If it DOES hve speaker wires, chec to see if they are hooked up to the speakers in the vehicle.
Mar 13, 2012 | Farenheit DVD-36 Car DVD Player
Can not get my car dvd player to play vidio, I have
u need to hookup the brake wire...and dvd wont play if u r driving
Jan 28, 2010 | Car Video Players
Clarion's VRX765VD player - Radio works but Audio in cd/dvd ?
Yes I do. I have a similar problem with my 2000 Chevy Suburban. I need a fix!
Jun 17, 2009 | Clarion (VRX765VD) Car DVD Player
I need the wiring diagram for this deck (vrx745vd)
Go to click united states...then type vrx745vd and look to your can download..
May 10, 2009 | Clarion VRX745VD Car DVD Player
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
No Audio on Jensen UV8
I just bought the uv8. Ist I must say i hate it, it was the worst purchase made. Amoungst others problems, your answer to solve no audio is this.
<<push mute button>> then volume up. you'll have sound. good luck
Jan 03, 2009 | Jensen VM9510 Car DVD Player
Car DVD player will only play sound through wireless headphones, not through speakers
We have a GMC Envoy which also does not allow us to play the sound from the dvd player through the car's speakers. Although we purchased the vehicle new with the dvd player already installed, it was installed by the dealer, making it after-market. I assume those that were installed in the factory work differently. Maybe this is the case with your's as well. Good luck!!
Aug 01, 2008 | Nesa Vision Car Video Players
The aux or auxiliary is used for external audio source (ipods, portable mp3 player,etc) If you are watchig dvd movies, the sound should come from the dvd and not from aux.
May 14, 2007 | Boss DVD-2000 Car DVD Player
There is no sound in my equipment
I have the same problem -- just bought a used minivan and can't get any audio with the DVD player. Were you able to find a solution? Any help would be appreciated! Thanks
Dec 06, 2006 | Clarion OHMD74 Car DVD Player
Myron & Davis AD273 Car Video Player Logo
23 people viewed this question
Top Myron & Davis Car Video Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
xxxxxx xxx
Are you a Myron & Davis Car Video Player Expert? Answer questions, earn points and help others
