Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA
My haier 5cu.ft. freezer stop freezing
My freezer is still plugged up but all the ice has defrosted out it and i noticed i in it the other day. so what happened i unplugged it and plugged it back up and still nothing. i turned it off and back on nothing. is there a light on it that tells me if it on or not i never noticed it if so.
    Problem Solver:
  • 11 Answers
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Posted on Nov 29, 2008
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Coils frozeup and iced on top shelf of freezer---did a defrost--when shut the door don't hear the shhhh sound-nothing blocking it and seal is good--light is on but won't freeze any food--threw out alot! ...
Defrost the unit totally so you can see no more ice, may take a day or more with door open, once done, restart the unit, check you can hear the fan running in the freezer, if not, replace fan unit, if you can hear it, the defrost timmer may have failed or the defrost element has gone. If the unit appears to work correctly, dont be fooled, the problem will return, if the unit does not work as it should, regas is required. Hope that helps.
Dont forget to vote for the solution, thankyou
Mar 04, 2011 | Frigidaire 13.7 cu. ft. / 388 liter...
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Sep 30, 2010 | Haier 4.5 cu. ft. / 127 liter Chest...
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Logo
261 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
