Question about LG LRSC26925 Side by Side Refrigerator
L.g. lrsc26925tt refrigirator - side by side - ice maker
when the ice tray calls for water,the water fills the tray,but at one far corner of the tray water spills over the side of the tray a bit.it eventually accumalates in the freezer.i can see that the tray has a slight twist in it.is that normal ? how would i correct that problem ? i cant remember if that twist was always like that or not.what could have caused that ? do you have any suggestions and how would i go about fixing the problem. thank you for your cooperation greg
should i get another tray ? how does the tray come off ? is there some sort of adjustment that can be done ? thank you
  • mejones51 Dec 12, 2008
    The ice maker has been "repaired under warranty" 4 times now n 16 months and now the inside of my freezer wall has a huge crack in it! Now it is being called in yet a 5th time in less than 2 years
  • 520 Answers
Greg...I got this fridge and had the same exact problem and more...long story short..I totally gave up on the ice maker in this unit.Very bad design. you will go crazy trying to keep that ****** going...trust me.
Posted on Jun 27, 2009
My Frigidaire side-by-side refrigirator is not making ice
Here is a simple tip that may help you decide what is causing this problem. If the ice maker has no ice cubes in the slots fill with tap water and allow water to freeze. If the ice maker cycles and drops the ice into the ice bin and then does not refill with water the problem is the 241734302 Water Inlet Valve (providing that the model number above your post is correct) If the ice maker only sits there with ice in the slots and does nothing the ice maker is the problem 5303918277 Ice Maker Assembly Testing the water control valve is as follows. I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 26, 2013 | Frigidaire FRS26H5AS Side by Side...
Ice maker maker not calling for water. changed mixer valve (new) still nothing water dispenser works. the icemaker runs it rotation ok still no water coming into tray
the fill line is frozen in the freezer .remove ice maker fill line is located behind maker use a hair drier to thaw.. could be ice maker too it controls the water valve.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Apr 27, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker wont shut off
So many different types. lots of info needed. In short, lg have DIPswitches on main board. By adjustment of these switches, the water in can be controlled.I dont think there is a water sensor on these makers per say.Does the water ever switch off at any time and if so, is the inflow time constant?. Assuming the solonoid valve is not defective.
Jan 17, 2009 | LG LSC26905TT Side by Side Refrigerator
Just installed ice maker cords, no water filling ice trays
Hi make sure that the arm on the ice maker is in the down posistion as it will only put water in the ice maker in this posistion. It will take a little time to fill so be patient as the timer in the front on the ice maker needs to cycle first. Make sure you have connected it all correctly to...
Dec 29, 2008 | Whirlpool ED2FHEXN Side by Side...
Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Jul 01, 2008 | LG LRSC-26922 Side by Side Refrigerator
Maytag ice maker wont fill upwith water
is the icemaker cycling at all? pull the front cover offf of the icemaker and verify that the gear isnt broken. if so replace the motor module. if thats ok the next 2 things could be either a frozen fill tube or bad fill valve..
Dec 08, 2007 | Refrigerators
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
LG LRSC26925 Side by Side Refrigerator Logo
884 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
