Indesit W 103 waste water catcher attachment & hooks
My Indesit W103 had a blockage & wouldn't drain & not knowing about the pre-chamber at the bottom I cleared the blockage by turning the machine upside down and removing the sump hose connected to the drum (with 2 outlets going from it). It was fixed with a 3 1/4 inch circular thick wire clamp which tightens round the sump hose with a 1 1/2 inch screw. There was no retaining nut and in trying to re-attach to the drum I've not been able to get it to stay attached to the drum. Should there be a nut to keep it sufficiently tightened? or is there a trick to this as it keeps coming loose for me.
Also I've now noticed that the 2 hooks suspending the drum have now become undone & the concrete weight is now resting on the floor (I removed top panel). One of the little plastic attachments has come off too and I'm not sure of where this goes and where/how to re-attach the suspending hooks. Is there an easy way for me to do this & avoid the whole thing breaking when I put it the right way up?
I'd appreciate any assistance you can give as, as you've probably noticed, I don't have any experience with this.
Thanks
Allan
  • allan_hainey Nov 24, 2008
    Thanks barkencoa
  • Washing Mach... Master
  • 3,463 Answers
Hi .
The plastic lug goes on the top frame of the washer, you should see where as the other will probably be still in place,
Then it is a case of pulling up on the springs and hooking into place.
If you cannot get the clip fastened, then use a large jubilee clip.
Good luck.
Posted on Nov 23, 2008
  • Barry Coates
    Barry Coates Nov 24, 2008
    Hi.
    Thanks for your reply.
    If I can help you any more, let me know.
    Cheers
My indesit WIB111 is full of water & clothes. how can I manually drain the water out?
put the machine in the emergency drain mode press the start button when it stops
http://www.manualslib.com/manual/76755/Indesit-Wib-111.html?page=13#manual
Dec 12, 2014 | Indesit Washing Machines
Shower not draining iflo waste
The domed drain plug has to be removed periodically, disassembled, cleaned, and reassembled. Be sure to disassemble it in order so you can reassemble it correctly.
While the drain plug is removed, apply drain cleaner in accordance with the directions
Nov 10, 2013 | iflo Home
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
Wixl123 does not drain after washing ?
Drainage problems can be caused by:
a) Blocked Filter chamber
b) Blocked Sump
c) Blocked Drain Pipe
d) Blocked waste pipe
e) Failed Pump
You can check the sump and drain pipe are not blocked by disconnecting the drain pipe from the undersink trap or waste pipe and lowering to a bowl on the floor. The water should drain out into this bowl under gravity if there are no blockages. Bear in mind if you have disconnected the drain pipe from an undersink pipe if youpour the drained water down the sink it will flood into your undersink cupboard. If this drains then you check the waste pipe or undersink trap is clear. You should also check the filter chamber if it is accessible on your washing machine (not all are). I would recommend you unplug the machine or take the fuse out of the switched socket before doing this. Drain the drum as above before doing this or you will get a gush of water coming out. You will usually have to remove a cover from the bottom of your machine to get to the filter chamber and twist it ant-clockwise to unscrew it. Check for any coins buttons etc trapped in there. If there is nothing there check the impeller will turn relatively easily by hand. If you still can't find the problem you might have a faield pump and I would recommend contacting an enginee
Apr 03, 2011 | Indesit W 123 Front Load Washer
Drain
Check the hose from the pump to the outlet, sometimes it can get blocked.
Make sure you can hear the pump working, you should be able to hear it running.
Hope this helps.
Jan 14, 2010 | Indesit Washing Machines
Pump pre chamber lid wont open
I have a PWE8168 and assuming yours has a similar arrangement:
1) Switch off water and electricity feeds;
2) Pull the washing machine forward a sufficient distance to allow you to tip it back so that you can gain access to the area next to the pre chamber lid. I found my tool box was handly at propping up the front!
3) A torch is handy at this point. Lie on the floor, and use a pair of mole grip pliers to release the springs securing the pipe attached to the left of the pre chamber filter (looking from the front of the machine).
4) Note that if you have not been able to drain your machine already your should have some towels/cloths and (eg) a tuppaware container ready to collect all the water.
5) Slide the pipe off and you should be able to get your fingers into the pump pre chamber and fish out whatever is jamming both the pump and the lid. I got a 5p piece for my troubles!
I would not say that this is a particularly difficult procedure and apart from water collecting, should only take 20 minutes, including reconnecting the pipe.
Oct 25, 2008 | Indesit W 123 Front Load Washer
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Washing machine fills continuously
It sound to be the water level switch but somes times the thin hose conected to the water level switch is broken... if you know how to dissambling and check visualy if you got a broken hose or a bad switch if the hose is ok try snaping the switch with an screew driver..any way is better to replace it with a new one....
Aug 03, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
131 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
