Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Dryer heats up, but acts like the motor isn't turning
I have a whirlpool leq9030pqo, the heating element went out a week or so ago, and I exchanged the element and the thermostats.
Now.. When I turn the knob to a specific time and then turn the switch on and press, the unit doesn't do anything. The heating element comes on and it gets hot. But does nothing else.. Could the on/off switch be causing this problem? Any suggestions would be appreciated.
  • 116 Answers
POOR AIR FLOW IS YOUR PROBLEM THAT IT /// DOES THE DRUM MOVE
Posted on Nov 30, 2008
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
I have a 2yr old Whirlpool Condensor dryer model no. AWA970B - 7KG. The dryer itself is going but it isn't drying the clothes. There is no heat coming out of the heat exchanger and the heat exchanger...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Element heats up... but does nothing else
Steve,
Sounds like it is the motor gone bad. You are getting power to everything else. as a last ditch effort try testing the continuity of the wiring from and thru your push on switch to your motor.
If that checks "ok" then you may have to replace the motor.
Nov 23, 2008 | Whirlpool LER4634J Electric Dryer
Now no heat after working for a few weeks with a new heating element.
By the time a dryer has worn out a motor and element, the wire connections are old too. You are going to have to check every connection, especially the push-on type for tightness and corrosion.
Nov 09, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
Sal De
fordexpert
Robert Rankin
