Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore 55639500 fridge.. no water from dispenser
Kenmore Refrigerator 106.55639500 side by side 2005 8(month?)
I was getting water in a gallon jug, slipped off and then no water. Now what do I do? I swapped out the ice and water micro switch and still the same. Ice still works from dispenser.
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
rickead1
  • 1998 Answers
SOURCE: Kenmore SbS refrigerator, water dispenser not working
lol ok the big black cauldron thing is your compressor there are two fans one near the compressor and one inside the freezer which ever one is not working replace and if its the one near the compressor unplug the machine till you do
Posted on Apr 30, 2010
espressonist
  • 1711 Answers
SOURCE: Maytag MFI2266AEU after dispensing 2
First Try to press the Door Alarm button for more than three seconds. This might reset the control.
If you don't have any results then you have a damage on the electronic Control Board which unfortunatly you need to replace and in a part that worth more $200.
Posted on Sep 21, 2010
  • 79 Answers
SOURCE: kenmore refrigerator side by side model
Your fridge has a dual solenoid water valve - one side controls the water flow to the dispenser, the other to the ice maker. It's possible that one side burned out while the other is still good.
Here's a photo of what it looks like:
Here's a link to the replacement part:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/218658000/0046/253/Model-25358682890/0582/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=25358682890&subCompDesc=Icemaker&brandDesc=KENMORE&modelDesc=Side-by-Side&blt=11
Before replacing the part, make sure the solenoid is in fact, bad. Get a voltmeter, and touch the probes to the electrical contacts on the solenoid, like so:
If the meter barely moves, the solenoid is bad.
If both solenoids test out OK, the other possibility is that the water supply line is kinked or clogged. Also, if your water dispenser has a filter (also on the back of the fridge), it might be clogged. My money's on the solenoid, though.
Good luck, and if this helps, please my answer!
Also, thanks to Zenzoidman for the pics.
Posted on Feb 01, 2011
Testimonial: "I've got someone to fix the problem, but this helps me understand what he might be looking for and what the part will cost. Thank you, Pat"
Kenmore model 106 9545751 side by side
The filtershould be inside the refurigator side of the unit. But a dirty filter would only slow down yor water flow to unit. Do you get dirty water from the water dispenser?
Sep 30, 2012 | Kenmore 50522 / 50524 Side by Side...
Kenmore mod. 106 water does not get to ice maker and when pushing despenor no rotation of ice out door
Hello Jim,
Sorry it has taken me a while toget back to ya i just got.
So on your refrigerator it very likely is the switch forthe cradlethat ya push to dispense ice and water through the door.
Unfortunitly modelnumber 106 asyou have listed is only the source number of whom your Kenmore was made by. Typically the full model# that does start with 106 willbe on a label on the ceiling or side wall of the refrig. section inside of it, reply with complete model number please and i will be able to help ya disassamble the door dispenser as well as provide you with part numbers and such
Thanks for using FixYa.Com
GENE
Sep 29, 2011 | Kenmore Refrigerators
We have a kenmore side by side fridge # 106-53644300. The ice maker quite working. Could this be due to needing to replace water filter?
Probably not due to the filter. Do you get a strong, steady stream of water from the dispenser? If not you need to look at the saddle valve, which is where the refrigerator gets water from the house's plumbing. Try screwing the saddle valve in as tight as you can then opening it up all the way. If that dosen't improve water flow you may need to call a plumber.
If you have a good strong stream of water to the fridge something may be wrong with the icemaker itself. It could also be the water valve on the fridge. Your best bet would be to call a professional.
Aug 07, 2010 | Kenmore 57029 Side by Side Refrigerator
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 29, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Jan 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Bad water taste coming out of Refrig
Hello collado36.. I'll give you a few ideas of things to try.. First off..is there a coffee scent in the refridgerator or freezer compartment when you open the door/s? If so, try emptying the fridge and wash everything with white vinegar and dry all surfaces with a soft cloth ( dish towel is OK).. air drying is OK but you don't want the food you removed to clean it to go bad.. Do you have any food in the fridge that may have been exposed to that coffee that may be 'out-gassing' that coffee smell?
The water comes into your fridge via an electrically operated inlet valve and is dispensed into the mold tray of your ice maker as well as the drinking water spicket. ( I am not sure if your model fridge has a reservoir to chill the water prior to dispensing but it probably does...but that reservoir should not be exposed to the inner refridgerator compartment nor should it pick up any scents or tastes from there either. )
In trying to diagnose exactly where the foul water is generated.. can you detach the incoming water feed line from the fridge and drain that into a large jug? Then check that jug for the same smell? If it only happens within the fridge then the white vinegar wash should help.. .if it also happens in the jug then your incoming water may be the culpret.
Another way to clean your water supply system to the firdge would be to detach the water supply line.. buy another length of flex water line with couplings.. and fill that section with white vinegar that can be forced thru the water system and clean it from the inside out.. if you do use this approach, make sure you flush teh system clean of any leftover white vinegar .. Hope these tips help you resolve your problem.. please get back to me if after you've tried these, they don't work.. Good luck..
Oct 14, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore model #106 55522400
YOUR PROBLEM COULD BE WITH YOUR INTERNAL ICE MAKER HEATER ELEMENT OR THE INTERNAL MOTOR OF THE ICE MAKER NOT OPERATING WELL.BEST YOU GET A EXPERT TO ATTEND TO THAT AS IT IS A COMPLICATED COMPONENT TO WORK WITH.GOOD LUCK
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water pooling inside fridge
check if there is a drain hole in middle of gulley at back of fridge. this is probably blocked. push something flexible down hole and check water drains freely by pouring a small jug of water in gully
Jun 05, 2007 | Kenmore 51262 / 51264 / 51269 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
220 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
