Question about GE JVM1440 Microwave Oven
Broken circuit board
I have an Amana hood microwave unit and I suspect that the circuit board is fried....I checkd the power cord and replaced the fuse and electricty is coming through the wires, but the display panel is blank and nothing is working on the microwave at all. Can you repair this? It's model is MVH350SS
  • GE Master
  • 9,098 Answers
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 25, 2008
Do the Sunbeam microwave oven have an inline fuse? I have no power in the unit at all.
Jack,
Most microwaves have a fuse inside the unit. Make sure that you have unplugged the microwave and then remove the cover and look for where the power cord goes into your microwave. Follow the black wire from the power cord and it should take you to either an inline fuse holder or a small circuit board where the fuse will be mounted. You will need to replace it with the same size fuse and the amp rating will be stamped on one of the silver collars. Hope this helps!
Aug 03, 2015 | Sunbeam Microwave Ovens
No power at unit. Power to plug
Jim, Take the screws out that hold the cover on your unit and then take the cover off. Find where your cord goes into the machine and follow the black wire from the cord, it normally should go to a small circuit board and your fuse is usually mounted on that circuit board. It will be a 15 amp fuse and you usually can get one of those at most appliance parts stores. If there is not a circuit board the black wire may go directly to an in-line fuse holder. Hope this helps.
Aug 11, 2014 | Hotpoint RVM1635 Microwave Oven
Has no power,
see the next steps: God bless your use the common sense, NOT feared.
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
see the block
Jul 31, 2012 | Amana ACO1520A Microwave Oven
I have a Kenmore Microwave Hood 721.63653300. I unscrewed one of the light bulbs and the glassw seperated from the base which cased a small pop now the unit will not run. I have check the power to the unit...
All Microwave ovens have a main fuse that is not accessible while the unit is mounted under a cabinet. Drop MW oven and replace the main fuse.
Dec 23, 2017 | Microwave Ovens
We had a lighting storm a few days ago and now my Amana radarange will not do anything, can this be as simple as a fuze? and if so can that be replaced without removing from the wall? thanks, Dean
Hello there and thank you for choosing fixya
Yes it could certainly be the fuse and that is where i would first check and if it checks out good than you may have a fried controle board or even fried wires inside the microwave
You may even have a bad power inverter also ok
Sometimes the boards can be more expensive than the unit costs you originally so be wise to this ok
keep me posted on what you have found
best regards Mike
Aug 04, 2011 | Amana Radarange Microwave Oven
After lightning strike & power outage digital display & oven not working. is there a fuse or reset button? or is the circuit board fried?
Start by investigating, open at the point where power cord goes in there is a fuse if it is o.k there is another smaller trans former powering the display board that normally uses thermo fuse, find out whether the thermo fuse is blown i hope this solves your problem
Aug 02, 2010 | Microwave Ovens
NO HEAT
Circuit board is bad. Cheaper to buy new microwave.
Sep 19, 2009 | Amana AMV1162 Microwave Oven
MVH350 not turning on
Have you checked the main fuse?
Jan 04, 2018 | Amana MVH350 Microwave Oven
Microwave does not turn on
There are about as many causes of this as there are parts in the set. To Start with, Check that the microwave is not plugged into a GFCI wall socket.. If it is, make sure the socket has not been tripped. If it has reset it. Make sure the set is unplugged for the rest of this. Follow the power cord in the unit to find the primary fuse. You'll need to test the fuse with a Continuity tester since this fuse usually a ceramic fuse and you can't just tell by looking at it. If that's good, the problem will most likely be a mini fuse on the controller board or a fuselink that's in side the small transformer on the controller board. If lightning is suspect, you can pull the board out and look at the circuit side to check to burned traces. Replace any MOVs that may be on the board otherwise any corrective work is just wasted. Back to the primary fuse... If the primary fuse is blown.... Chances are that you have a bad Diode in the Tube side of the circuit. Depending on the age of the unit... it maybe a HVR-1 diode. If their are no relays on the controller board, check for a bad Triac. It could be just time to junk it.
Sep 07, 2008 | Microwave Ovens
GE JVM1440 Microwave Oven Logo
76 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
