Question about RCA F35673MB 35" TV
Only receiving Channels 50 and above; no lower channels
My mom's RCA television is about 9 years old. Suddenly it started receiving only channels above 50. None of the channels below are coming through. The cable company has checked it out and assure her it is not a cable issue. Could it be the tuner? Is it worth fixing?
  • GIANTS-69 Dec 19, 2008
    Sergeant:
  • 308 Answers
It could be anything from corrupted data in the EEPROM (a memory IC that stores all the channel information and picture settings) which is usually caused by bad ground solder connections inside the tuner itself which is built into the main circuit board and would have to be repaired, not replaced or components inside the tuner section of the main PCB. With that being said - if you have to get a technican to come to the house and repair the set then it would probably be best to buy a new HDTV set. If you can take it to a repair shop capable of fixing the tuner, it could cost close to $200 to repair is my guess, and may work OK for another year or two before the picture tube finally wears out.
Posted on Dec 29, 2006
Why does my RCA f32632sb not receive all channels available? Other tv is fine. this one is an older model(free off of craigslist) and it won't get a bunch of channels. I have cable 2-57 in BC Canada. ANY...
I have a old RCA tv model F32632SB...and im having problems autoprogramming it...when I start the autopramming it starts on channel 14...after its done goingthru all the channels still no picture on all channels except channel 11...ive autoprogrammed the tv 50 million times still nothing... I tried the cable cord in another old tv and the cable is fine..anybody know ????
Nov 28, 2010 | Televison & Video
Television changing on its own
my television keeps scanning from channel 4 to channel 37 and the volume keeps going up loud and lowering by its self coule you tell me what could be wrong the television is only 1 year old thank mrs yardley
Dec 16, 2009 | RCA TruFlat 27F520T 27" TV
No sound on 3 channels
Check if the sound adjustment is in STEREO-SAP-MONO mode
Change to STEREO mode
Jun 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
RCA L37WD22 not receiving analog
The problem is on the signal board. Same problem and fix for L42wd22, and L46wd22 models.
I can fix this board for a FRACTION of what a repair tech will charge you. Email me at aplusrepairs@triad.rr.com
May 11, 2008 | RCA L37WD12 37 in. LCD HDTV
I cant get the tv to go to higher channels
Most tv's have an Antenna mode and a cable mode. If you have cable tv service, the cable mode must be selected in order to receive channels higher than 23. Then you must auto program the channels thru the menu screen on the tv to receive the channels above 23. If you have a house antenna or rabbit ears, its hit or miss on receiving all VHF and UHV channels.
Jan 12, 2008 | RCA 20V500T 20" TV
Sound and picture distorted only on lower channels
Bad tuner.......they are electronically divided in sections called
bandwidths, i.e. 2-6 , 7-13 so-on.........T.
Give accurate model # / service # for RCA part #............
Nov 06, 2007 | RCA F32450 32" TV
TV is on and just suddenly starts changing channels
the switches in the front of the tv are usually the cause of this kind of problem. the fix is to replace all of the switches, because if 1 is bad the others are not far behind. each switch from rca is $5 to $10 each. good luck.
Nov 18, 2006 | RCA F36649 36" TV
Televison & Video Logo
97 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
