Question about Ruud Central System Air Conditioner
Water heater problem (no leak on floor)
WH problem with no leak on floor. Can hear water flowing thru the CW line, but no water running in house. Electric bill high (no one living in house). Water bill remains the same. Any suggestions? Electric Co. says water leak in line under house (wouldn't that increase the water bill?).
    Problem Solver:
  • 14 Answers
Shut off the power to the hot water heater wait 5 to 15 min. If the noise stops it is the water heater eating up electricity. Turn it back on if noise starts again feel about 5 or so feet down the hot water line. If this line is hot you have a leak beyond the hot water heater. If you still hear it when the power is off to the water heater. next turn the water off on the cold water line at the water heater with the power off also Look at the water meter and see if the hand or wheel on the meter is moving and it should no be. Also think if the breaker to the hot water is off the electric meter should practically stop if no refrig oe anything else on. Have someone watch the electric meter and switch 1 breaker at a time leaving the one you just shut off in the off position until you cut them all off. Should the meter still be moving you have a main service cable shorting somewhere call the power company to advise you further if this is the problem.. Should just cutting the circuit breaker for the hot water heater stop the noise and down the hot water line is not hot then you are probably wasting power due to a thermostat or element inside the hot water heater.. Thank you j
Posted on Dec 19, 2008
Water is leaking from the floor vents what could be the proble?
Check your heater radiator. It is usually mounted behind/near the glove box areas on most cars. It is like a small version of the large radiator that is mounted on the front of your vehicle under the hood. Antifreeze and coolant (does it smell a little like antifreeze?) flows thru your front radiator, thru the block and hoses, and cycles thru the radiator for your heating system. If the radiator is leaking, often it cycles thru the vents on the interior.
Another possibility MIGHT be the AC system and condensation/AC coolant that is building up in/on the lines and transferring thru the vents.
Aug 18, 2014 | 1999 Buick LeSabre
Is my water heater leaking?
You have water leak that you can hear running water.
Could be broken pipe under house.
Could be water running out of tank at TP valve.
Turn off all water taps and put ear against each pipe at tank.
If TP valve is leaking, then replace TP valve.
If pipe is broken under house, then call contractor.
Copy following links for troubleshoot walk-thru.
http://waterheatertimer.org/images/Ear-against-pipe-200.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
Aug 28, 2012 | Reliance 606 Series 40 Gallon Electric...
The heater,which is only about a month old, is making an excessive splashing sound. I understand that water is flowing over coils, but it wasn't this noisy during the first weeks. Is this normal?
The only 'splashing' you could hear from a heater is air being pushed thru the system. Is your pump basket full of air bubbles? Are you getting air bubbles at the returns in the pool? If so, the noise is from the air going thru the heater...fix the air leak at the pump suction line back to the water inlets to the pump and the noise should cease.
If there is no air you should probably get ahold of a warranty rep to ensure the noise is not from a stuck bypass valve in the heater or improper water connections / poor plumbing hook-up.
John
Jul 29, 2011 | Pentair Mastertemp 460732 250000 Btu Gas...
My water heater runs constantly lately and i noticed water at my property line and around half my house. i can't tell where the leak is coming from. house is on slab. i am afraid to ask. the floor...
Does the hot-water line running from the heater go into / under the slab before going back into the house?
Or does the pressure relief valve drain line on the water heater go into / under the slab ?
It could be as simple as a faulty pressure relief valve on the heater (which would be the most likely of the two possibilities). When the water heats, the pressure builds in the tank, the water flows out the faulty pressure relief valve and down the drain line under the slab.
A plumber would be the person to call.
Charlie
Feb 19, 2011 | Kitchen Ranges
There is water puddling up on the passenger side floor and actually seems to be coming up thru the floor, nothing leaking down from anywhere.
ok you got some possibles.1 check cabin filter if signs of water than drain plug on fire wall cloged.causing water to enter by over filling and no were to go.but thru the filter.easy fix.also if you losing anti-freeze than that will point at your heater core leaking from line or core itself.need to test it,turn on heater and check floor with a towel. lay it on floor going up to firewall inside truck.go for a good drive so pressure can build and heater on.while engine hot look at floor towel top part by firewall wet prob heatercore.also check if door is wet to eliminate possbility of door seal leaking.let me know.
Aug 13, 2010 | 2004 Chevrolet TrailBlazer
ATWOOD WATER HEATER
you will need to have a 115 curent for electric, run a line off the panel box, turn off water to the house drain it down, disconnect the lp gas line and cap it off, remove the water heater, install the new heater run the cold side water to the cold side {blue on the heater} the hot side to the red, take the cover plate off on the water heater run the wires, hook up the groung wire then the red and white wires to the wires comming off the panel box,, fill the water heater with water have a open faucet on the hot side, and bleed the air out, DO NOT TURN ON ELECTRIC TILL THE AIR IS OUT OF TANK AND WATER IS FLOWING THRU COMPLETELY, after you get water commming out of the faucet turn it off and turn the electric on to the water heater ,, wait about 30 min, you will have warm after an hour it will be hot and you are done,, good luck write me if you have questions, gary1121@aol.com
Jun 29, 2009 | RTO Atwood Water Heater - 6 Gal LP
My ranai tankless heater is not working
Check the electrical supply to the unit but my guess would be an issue with the water flow sensor.
Mar 16, 2009 | Rinnai Water Heaters
It sounds like you might have scale buildup on the elements. If its a dual element unit it will ground it self out and it sounds like its boiling. constance usage of electricity, but no water usage. Drain it, and pull the element and replace the element.
Jan 17, 2009 | Water Heaters
Ruud Central System Air Conditioner Logo
222 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
