Question about Moyer Diebel 24 in. 501HT Built-in Dishwasher
Water not draining, how should the switch be set?
We just picked up a 501HT dishwasher that was used in a community hall and have put it in our new hall kitchen. Need to know two things 1- How do you setthe three switches at, near the bottom and 2- how do you hook up the drain, I presume that you run a hose up and back down to form a trap. When we run it, water came out the door and didn't drain. Not sure if drain is pluged, not hooked up properly or one of the switches is not on the right setting?
  • dabean Mar 02, 2009
    My 501HT has stopped draining.
    It runs through a couple of cycles until the water inside builds up enough to leak out through the door.
    I have tested the cam switches #3 and #4 and they are opening and closing as the cam turns.
    How do I test the drain S/V and how do i know if the pump is reversing?
    Scholar:
  • 86 Answers
Hello there
I hope you 've sort out the problem by now if not please email me your problem again and I'll sort them out for you my email address is dickson@lau.com God Bless have a nice day Dickson
Posted on Jul 02, 2009
Hi There,
I am not an expert, but I have the same dish washer. The washer motor may not run in reverse. I had the same problem and a couple of the timer switches and the started relay were bad.
Fixed it but two years later it has the same problem. BTW, my unit still has a timer relays, the new once don’t'
Also don't switch on the delime switch, this will hold the cycle until you switch it off again.
Regards,
Thomas
Posted on Jan 18, 2009
There is problem with the drainage from my guess. There is waste water left after turning it on, and it doesn't go away. However, hot steam and water are running properly. I found a guy who fix the pump,...
Hello Johnnybl
Hope you've solve your problem by now. Without more information I guess your drain valve is defective and not letting the water to drain out. All the best Dickson
Jan 21, 2011 | Moyer Diebel 24 in. 501HT Built-in...
Moyer Diebel 501HT goes to temp 57 degree C, it should go atleast 71 degree C, What should i do ? thx.
First item to check would be the high limit switch attached to the outside of the booster. Should have 2 wires. Switch is the size of a dime. The switch has a reset button at the centre. Just push in slowly. You should hear or feel the slight click. Do not touch the wire or terminal at the switch when power to machine is on.
Sep 13, 2010 | Moyer Diebel 24 in. 501HT Built-in...
When we close the door and put switches on, only the temp light comes on. nothing else happen. Thanks
Could be the switch marked delime is in the on position.. That switch should be in off position. (pushed in at bottom)
Sep 11, 2010 | Moyer Diebel 24 in. 501HT Built-in...
I have just purchased a used 501HT model and had it installed by a plumber and electrician. It does not seem to work, when I close the door and push the start button. Can you help ? Also, there is a liquid...
If your dishwasher has not worked since the intial set-up. It could be any number of problems. I would check and make sure your machine's electrical is hooked up properly. A common mistake during set-up of high temperature machine is an electrician will hook it up to 120V when it should be hooked up to 208V. There is also a service switch located on the inside of the lower service panel, usually marked FILL/ OFF/ ON
This switch will need to be in the ON postion. Also the machine has a extended wash/deelime switch located under the door this will need to be turned off in order for the machine to begin a cycle.
You can use a powdered detergent. A liquid detergent is the best way to go. Liquid is the most economical when set-up and titrated properly, as opposed to manualy filling the machine with powder every load. Powdered detergent often leaves a chemical residue on your warewash.
Regards
Dec 21, 2009 | Moyer Diebel 24 in. 501HT Built-in...
No sanitizer
Hello
If you have a 501HT you shouldn't need a sanitizer because the machine sanitizes using hot water. The final rinse temperature should reach 82 C to kill all germs. The chemical pump's element tubes may be worn out. This would prevent the detergent and rinse aid from being dispensed into the machine. If during the last 20 seconds of the cycle the machine doesn't reach the final rinse rinse temperauture, this may mean the heater coil will need to be replaced.
Nov 29, 2009 | Moyer Diebel 24 in. 501HT Built-in...
My 501HT has stopped draining. It runs through a couple of cycles until the water inside builds up enough to leak out through the door. I have tested the cam switches #3 and #4 and they are opening and...
Hello Dabean
Have you sort out your problem yet if not please email me your problems and I try to sort them out for you my email address dickson@lau.com God Bless have a nice day Dickson
Mar 02, 2009 | Moyer Diebel 24 in. 501HT Built-in...
Dishwasher not draining
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Moyer Diebel 24 in. 501HT Built-in Dishwasher Logo
274 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
