Question about Microwave Ovens
Jennair jmc8130dds fuse blown
We have the jennair microwave and oven below, mounted inside our cabinet. yesturday i ran the clean cycle on the oven, and then when turned the microwave on to heat up some soup, i blew a fuse. the breakers are not tripped, so we've concluded it was the fuse. do we have to pull the whole thing out to get to the fuse? The manuals don't show the location, and i read on previous blogs it's behind the control panel. there is a small square cover with two screws inside the microwave... is it behind there? do you have any literature you can share that shows an assembly blowup?
  • 1 more comment
  • klkillee Nov 24, 2008
    So we pulled out the entire unit, oven and microwave, last night. Guess what? Jenn-air added a little toggle switch breaker on the back side of the microwave near the plug. it had trippled. that's all it was, no blown fuse. thanks for your help, i will go to that website you mentioned and printout the illustrations so we have those next time. thanks for everything and have a wonderful thanksgiving!!
  • edmoncayo52 Dec 01, 2008
    suddenly my oven stopped working, I am assuming its fuse is blown, but I don't know where it is located.
    Thank for your answer
  • kimba207 Dec 05, 2008
    I have the same problem.  After using the cleaning cycle on the lower oven, the micro stopped working.  I am not having as much success with detaching the unit to reach the toggle switch.. will try further detaching in the morning..any suggestions greatly appreciated
  • 5,911 Answers
I apologize for not getting back to you sooner. It took me a while to locate the information you requested. To answer your initial question, "YES" you will have to pull the whole unit out to access the fuse. The fuse is located on the input filter assembly board inside the oven. You will need to remove the exterior case to access it. If you go to you can find helpful illustrations, along with part numbers. Just type in the model number you provided and look at drawing number 5. This is a list of all the internal controls. The fuse is listed as item number 4 in the illustration and mounted to the filter assembly (item 18). You can purchase these appliance fuses at any hardware store as long as they are rated the same (20 AMP). CAUTION: Please ensure you UNPLUG the unit before servcing any internal components. I hope you find this information helpful. If you need additional assistance, please let me know.
Posted on Nov 24, 2008
  • Jeff Rockwell
    Jeff Rockwell Nov 24, 2008
    Glad I could help and it didn't require too much work on your part. Nice feature they added. I wish all microwave ovens were equipped with an external breaker. You have a wonderful holiday too!
Jennair microwave jmc813odds wiring diagram
Request a wiring diagram directly from Jenn-Air.
Jun 22, 2017 | Microwave Ovens
Jmc8130dds microwave died. any thoughts. previously numerous messages about locking the screen on its own.
I think it is time to replace the microwave oven, the fuse has blown and there are numerous reasons why, shorted power transformer, shorted filament winding in the magnetron, cracked high voltage diode with a high level short, and a shorted high voltage capacitor, not to mention issues with the keypad and microprocessor control board.
Mar 20, 2012 | Jenn-Air JMC8130DDS Microwave Oven
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
It's completely dead?? Not sure what happened. Power supply is fine.
Microwaves that suddenly loose power could have many causes with the easiest being a blown fuse inside the cabinet of the oven. To check for this unplug the unit and remove the screws that hold the cabinet in place. Be sure to not touch any of the electrical components inside to avoid shock. Visually follow the path the power cord takes as it enters the unit. The fuse ( usually clear glass with metal ends and cylindrical in shape ) should be located not far from where it enters the cabinet. Once located use a fuse puller or other means to carefully remove the fuse to check the element inside. If the fuse is blown take it to a hardware or electronics store for replacement. These fuses are cheap as this has happened to me before. Good luck!
Jun 19, 2011 | Whirlpool MH6110XE Microwave Oven
Jenn-Air Microwave Oven (JMC8130DDB) is dead. CB in Main (Box) is OK. Microwave is mounted in a wall cabinet over a Jenn-Air electric self clean Oven. Oven was in "self-clean" when the Microwave...
I read your comment about needing to remove the control board to inspect it for damage. Looking at the diag. below, all you need to do is open the oven door and remove the two screws (#2 on diag.) fastening the brackets that hold the board in place and you can take it from there.
Refer to the diag. below If it was me, I would start by turning the breakers for both ovens OFF, then, in getting someone to help me pull the oven out, disconnect the power cord and check the power circuit protection devices like the fuse #4, located above the fan and the power board #25 also located on the back of the unit. Before replacing the blown fuse, inspect the wiring, If the unit is mounted over an oven that was in the Self Cleaning Mode that reaches temps. of about 500 degrees, there is a chance that a wire's insulation melted and shorted the unit.
If you need better resolution and the names and prices of the components on these diagrams, click on the following links: for the first diag: for the second diag:
I hope this info is helpful to you. If you need further assistance, just place a comment.
Mar 02, 2011 | Jenn-Air JMC8130DD Microwave Oven
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
No Power to Jenn-Air Microwave JMC8130DDS
I just had the same problem. Our unit is about 5 years old. I was running the self-cleaning mode, and put something to heat in the microwave. It heated at first, then all power to microwave went out. I read the above description and we pulled the entire unit out, and there was a reset switch on top of the oven. Pushed it and the microwave was back in business. I would have been very upset if I had called a service man and he spent 5 minutes, just as we did, to pull it out and reset the circuit. We turned all power off prior to pulling out the unit. It seems JennAir should admit this is an innate design flaw and offer some sort of compensation or come up with a repair kit to fix this issue....
Dec 27, 2007 | Frigidaire GLMB209D Microwave Oven
Microwave Ovens Logo
225 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
