Question about HP Photosmart 612 Digital Camera
HP Photosmart 612 Red-Yellow-Blue screen, etc.
Slightly used camera as a gift, took first picture after changing to "no-flash". Picture was taken as if subject was moving fast. Some were o.k. Then the camera started a diagnostic loop for checking blocks or something like that. Unfortunately, I interrupted it. Then when I attempted to take more pictures, they continued to be the same problem, and then the camera's batteries failed. I placed new batteries in and the on-off button only went to the right a little bit. After power was turned "on", the screen only showed three stripes - Red-Yellow-Blue. I tried new batteries, same problem. I tried pressing all sorts of buttons after I put the batteries in and nothing changed. I read in the manual that when new batteries are inserted the screen should be asking for language and date and time, etc. I never get that far. Camera worked fine before it was given to me. Should I get a new camera or is there a way to "restart" the camera like a computer??? Thanks for the input.
  • 2 more comments
  • Crystal Rogers Dec 10, 2007
    I have the same vertical stripe problem. Tried restarting but camera will not go off unless batteries are removed. When batteries are put back in and camera turned on again the stripes are back.
  • superchels01 Jan 29, 2008
    Hi
    I have same problem but mine occured when i inserted new flash card
    should i bin the camera
  • camfix May 23, 2008
    was taking pictures ... camera started the diagnostic loop ... I interupted ... then the RED GREEN BLUE rear lcd viewfinder appeared. camera powers on but NO lcd numeral status readout available. HP website says : not operating / requires servicing .... can I service this myself as I am technically minded ?
  • David Friesen
    David Friesen Jul 07, 2008
    One third of the screen is red, one third blue, one third green
4 Suggested Answers
SparkGap
  • 363 Answers
SOURCE: memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Posted on Oct 22, 2007
  • 153 Answers
SOURCE: HP 945 lens stuck out, red light on steady, white screen
Ok, here's a couple of long shots to try...
If there is a backup battery remove that also and let it sit for some time with the power switch in the on position (if it has one)
also check the battery contacts are clean. Refit both batteries and try again.
Beyond that unfortunately it sounds like a main board failure. If you have any warranty on the camera return it, if not its likely the cost of replacement would be fairly high but worth checking with HP.
If your handy and fancy a go at it yourself it may be worth opening it to check nothing has become dislodged, but this is unlikely. else pick up a faulty one off ebay, one with a broken LCD or lens and have a bash at swapping the main board out yourself.
A WARNING ABOUT OPENING DIGITAL CAMERAS THEY BITE
Before opening a digital camera its recommended you let it sit for some time (like a week) with no batteries in. There ia a large capacitor (like a battery) which can be charged up to 300v if you touch the contacts or anything connected to it it really is like a shock from the mains.. I have been bitten many times...
This can damage the delicate parts within because of high voltages but more often because you almost always drop the darn thing..
Best of luck
Posted on May 26, 2008
SOURCE: camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Posted on Feb 22, 2009
My apex at2402has a blue screen
your' TV is in VIDEO mode... connect your cable or sat. or DVD player or cable box etc. to TV using the VIDEO jacks>>>>red , white , and Yellow wires....picture should be on TV now.
other ways to get a picture also....changing TV from VIDEO mode TO TUNER mode...etc
May 19, 2010 | Apex Digital AT2402 24" TV
Constant Charging Flash HP Photosmart R927 digital camera
First I'd try turning the flash off, a manual option on nearly all camera's. Take a couple of photo's without flash, and turn the camera off and on a couple of times then turn the flash back on to auto.
If that doesn't resolve the problem, I suggest going to the HP website, follow links to support and/or downloads and see if there's a firmware upgrade for your camera.
Apr 26, 2010 | HP Photosmart R927 Digital Camera
Digital Camera HP Photosmart M517 Want to take a picture of my computer screen to send by email. Flash goes off every time and leaves a bright white light that obscures the screen. Can I disable the flash...
Press the flash button (just under the viewfinder) to cycle through the flash settings. Your choices are Auto Flash, Auto Flash with Red-eye Reduction, Flash On, Flash Off, and Night.
If you want to capture the screen image, you're better off using the computer operating system's screen-capture capability. This will give you the screen exactly as it is, without the distortions inherent in converting to an analog image and then converting it back to a digital image.
Mar 15, 2010 | HP Photosmart M517 Digital Camera
Horizontal Lines Thru Picture on R967 Camera
I suspect it is a problem with CCD sensor. Let me know if HP were willing to repair it for free.
Mar 08, 2009 | HP Photosmart R707 Digital Camera
HP Photosmart R707
Hi there is a firmware upgrade on the HP website from 2006, it might be worth trying...
Jun 12, 2008 | HP Photosmart R707 Digital Camera
Problems with my Polaroid izone 300's picture...
This is a CCD failure This is a known problem and the manufactures will replace the camera if it comes within their terms. Check out Polaroid on this
Aug 03, 2007 | Polaroid iZone 300 Digital Camera
Picture Problem
Has this camara got Movie mode . If so is it selected to movie and not photo check your manual
May 06, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
HP Photosmart 735 "unsupported image file"
You might want to try a different memory card.
Jan 21, 2007 | HP Photosmart 735 Digital Camera
Pictures are all white when using the flash
it seems that the shutter of your camera is having a problem with. normally whin it gets stucked fully open it creats such problem. you need a help of a repairer.
Nov 03, 2006 | Fuji FinePix S5100 Digital Camera
HP Photosmart 612 Digital Camera Logo
80 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
