FixYa.com
Tags:
Nikon Speedlight SB-600 TTL Flash
Nikon iTTL problem
By Brad - usenet poster
I have a Nikon D70 + SB600 flash. A very serious problem is that either with
the build in flash or the SB600, the preflash that is used to TTL calculate
the power of the main flash is well separated from the main flash about
20-30 msec. So every time you can see two distinguished flashes. Some very
sensitive people can close their eyes after the first flash, so when the
main flash lights, they have eyes closed. This effect in a wedding for
example can be a disaster, as 90% of the shoots finds the bride with the
eyes closed.
I have test a Canon 20D + 550EX flash and the preflash was so close to the
main flash so subjectively we could see only one flash. This means less than
10 msec. No one could close his eyes so fast, so there was no problem.
My question is: Is a specific problem to the build in and SB600 flashes, or
is general in Nikon iTTL; It is the same with SB800; What are your
experiences;
Dimitris M
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 09, 2007
FixYa! (100)
Daveemtb
Rank:Wiz Wiz
Rating: 83%, 73 votes
I had this exact same problem. When I upgraded the firmware on my D70 to version 2, the preflash seemed much closer to the main flash and the problem went away.
Some people will always have a magic ability to blink just when the shutter goes. I can't work out why, but a minority of people do it far more than most people do. Wedding photographers know them as "blinkers." They are a nightmare to photograph.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 04, 2005
Helpful (85)
Perkins
Perkins - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I see this problem happen with my Canon S100 which has no moving
mirror and a very quiet shutter, although the two flashes are maybe
more than 50 msec apart.  However, I never saw it happen with any
regularity using film SLR's with no preflash.
To the OP: Try using the FV Lock setting to suppress the preflash and
see if you still get closed eyes.  You will have to take a test flash
to set the initial exposure, but after that, FV Lock re-uses the same
exposure for further shots instead of measuring again with a preflash.
Solution #3
Helpful (85)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
Dimitris M <nos @ath.forthnet.gr> schrieb:
I noticed the same problem. I see three solutions:
Use FV lock to trigger the preflash well before the main flash. This
works, but it is a daunting to use. Also, the metering in the camera is
different. I think it switches to center-weighted metering, but I'm not
completely sure. I couldn't find it in the manual. On some pictures the
exposure is off due to this.
Disable the preflash. Switch the flash to "A" mode (not "AA", there is
still a preflash). It is in the custom setting of the SB800, maybe the
SB600 doesn't have it. This works well, but you have to set the
aperture, ISO value and zoom manually on the flash. I don't know why
there is still a preflash in the AA mode, I see no reason for it.
Use GN mode (SB800 only). This is manual mode without preflash. You have
to dial in the subject distance on the flash which is easy and quick,
everything else gets transmitted automatically.
Walter
Solution #4
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
Thanks to all for your answers.
Dimitris M      dio @ath.forthnet.gr
Solution #5
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
On Mon, 20 Jun 2005 02:06:30 +0300, "Dimitris M" <nos @ath.forthnet.gr>
wrote:
I've not yet got either an 800/600 (I'm thinking about it, so I'm prowling
threads about them) but:
Presumably the flash is being held to one side, as presumably the D70
wouldn't have to issue command-flashes to SB600/800 if it was mounted on
the hot-shoe?
Although less convenient than the "wireless" mode the D70/SB600/800 use,
could you connect a shoe-extension code (I assume they exist) between the
two, and would this stop the communication pre-flashes?
Regards,
Graham Holden (g-holden AT dircon DOT co DOT uk)
There are 10 types of people in the world;
those that understand binary and those that don't.
Solution #6
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
Pepe <p @home.nl> schrieb:
No, the SB80DX doesn't work with iTTL, and the D70 doesn't do DTTL.
Avoid this combination.
In case you meant the SB800, it has the same problem with the preflash
as the SB600.
Walter
Solution #7
Not Rated (0)
Hart
Rating: 0%, 0 votes
Ken Tough <k @objectech.co.uk> schrieb:
This problem is real, I'm seeing it too and I know many other people
that experienced it too.
Walter
Solution #8
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
There is a short lag with the SB800.  Not long enough to cause eyeblinks
as far as I know.  I do get eyeblinks with the Canon S100 point-and-shoot.
I seem to remember with the SB800 (and probably also SB600) there is a way
to pre-meter the flash exposure, so there's no preflash needed.
Solution #9
Not Rated (0)
Grant
Rating: 0%, 0 votes
It doesn't seem all that likely to me that a 30 msec lag is enough to
cause a blink which disturbs the picture.  When a blink response is
elicited by a flash, and measured by the EMG signal (not even the
moving eyelid) the latency seems to be around 55 msec in adults.
The blink itself takes 200 msec to complete, so eyes closed would be
100 msec or so after the flash as I make it.
 http://tinyurl.com/7hyed        57.0 +/- 4.9 msec in adults
The "startle reflex" seems to be faster for acoustic stimulus than
flash.  Given that the mirror moves and the shutter opens well in
advance of the flash, perhaps it's a case of the person reacting
to the sound of the camera in anticipation of the flash?  Maybe
some cameras are better or worse at that.
Ken Tough
Solution #10
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
"Dimitris M" <nos @ath.forthnet.gr> skrev i meddelandet
Here you can learn more about NIKON D70 and flash.
<http://www.mir.com.my/rb/photography/companies/nikon/htmls/models/dig...>
Not all functions are avilable with SB600 better go for SB80DX.
Pepe
Can you Help with these Flashes problems?
Nikon SB600.
Hi, I read your post about your... Answer This...
no TTL information for Sb-600
The autofocus light on the... Answer This...
nikon SB600
Flash ready light appears... Answer This...
SB-600 body is broken
I have a SB-600 plastic body is... Answer This...
SB-600 won't flash
Hi, I have dropped it , after... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
