Question about HP Pavilion dv6000z Notebook
I can not eject the disc drive of my laptop hp 2500
Can not eject disc drive, it is not opening when press eject just emitting light.
  • 837 Answers
Did you try straightening out a paperclip and inserting it into the release hole on the drive?
Posted on Nov 23, 2008
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Where is the eject button to open my disc drive?
In some laptops you press and hold the control key and then the disc eject button (its a key on the keyboard).
Sep 20, 2014 | Computers & Internet
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
How to eject disc from hp envy 14
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Aug 16, 2012 | HP Computers & Internet
My hp laptop keeps ejecting disc itself when i insert any disc. Wat do i do pls
> keep ejecting
The disk-drive is having a mechanical problem, i.e., it is not fully-loading the disk,
or it is not detecting that the disk is fully-loaded. Therefore, it assumes that the open/close
mechanism is "jammed", and so it ejects, to indicate that the disk-loading was not completed.
Replace the disk-drive.
Jun 26, 2011 | HP Computers & Internet
Dvd player on my hp computer will not open to insert dvd or cd's
If it doesn't eject right when you press the eject button right after you power it on, then its not being locked by software and there is either a defect with the button mechanism, the ejecting motor, or the power system.
If you don't need to use it often, you can try manually ejecting it with a paperclip. If it reads the cd / dvd discs, then it is just an issue with the button or motor. If it won't read discs then you'll probably need to replace the unit. If your HP is a desktop, you can use any type of drive (BluRay, CD DVD DL, R, RW etc), as long as you verify it has the same data / power connectors (PATA / SATA). If your not sure the difference, here is an image of two hard drives that have the different connections: http://www.advantage77.com/images/Pictures/Hard_Drives/sata.jpg
If you have a laptop, you can try contacting Hewlett-Packard with your model, product number, and serial number (on bottom of the laptop) and they may be able to send you an appropriate replacement.
Another alternative would be a using a portable USB disc drive.
Please leave feedback if this was helpful. Thanks.
Apr 15, 2011 | HP (381400-001) (381400001) Plug-In Module...
Cd put in drive, is stuck and will not open. Have
Power down.  Now power back up and press the eject button at the top of the keyboard and hold until disc ejects.  If that don't work, then you gonna have to open this thing up and physically take the disc out cause something is blocking it from ejecting.
Nov 16, 2009 | HP Pavilion Media Center a1330n - AMD...
My disk drive is stuck and won't open
Try first a soft eject: Go to my computer, Point the CD-ROM drive, right click mouse button, and choose eject. If that dose not work, examine the face of the drive and look for a small pin hole. Insert a blunt paper clip in the pin hole and press gently. The drive should open.
Hope it helps.
Aug 29, 2009 | Sony VAIO PCV-V200G PC Desktop
Packard Bell EasyNote R4 - CD Drive won't open itself
this is the common problem..open the drive... see for any speck inside.. this is a minor problem.. thank u
Dec 03, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion dv6000z Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
