Question about IBM NetVista PC Desktop
No video The computer was rattling and once the side panel came off the video card was partially out and the blue piece that holds the video card in was just tumbling around inside. There was also a little metal piece but I have no idea where that goes. Its like a clip with a weird screw looking piece in the middle. The thin tin metal that went around where you plug the monitor in on the inside was all crinkled up & I tried to flatten it back out. Do you think it may need a new video card or more extensive repair?
  • cat1370 Nov 24, 2008
    thats what I thought too Thank you
  • 53 Answers
It looks like you need a new video card.
Posted on Nov 24, 2008
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
Tip
How to resolve a "NO VIDEO" problem on your Desktop computer?
1. Turn the computer off...
2. Remove the Power cable and drain the power by holding down the power button for 10 seconds...
3. Remove the side panel of your CPU Tower (refer to manual how to remove side panel)...
4. Loosen the screw of your Graphics card and remove it then replace it back!
5. Connect all cables and put the cover back...
6. Turn your computer back on!
Note: This trick applies to desktop pc's with video card. If your graphics is integrated with your motherboard, try reseating the video cable instead.
on Jun 08, 2010 | Computers & Internet
How to replace the integrated ATI Radeon Xpress 200 in Compaq Presario SR1834nx
If the video card is in a pci slot: Just turn off the computer, remove the power card, remove the case. Turn the computer on it's side and there will either be a screw that holds the card in place or a latch with a screw on the back of the computer that hold it. Once you remove what is holding it in the slot simply lift the video card out of the slot.
If the video card is on board then you can still insert another one in the pci slot.
Jun 07, 2012 | Compaq Presario 7470 (163881-004) PC...
Video card quits working, or displays partial video before it stops working all together.
More than likely the video card is overheating. If it is a gaming video card, it might have some sort of cooling system with a fan built on to the card. Make sure that fan is spinning, if not - that is probably the main cause of the issue. You can lookup your video card manufacturers website for service or replacement parts.
If the fan is spinning, make sure there is no dust or debris. Clean the fan by using compressed air or a blower on low setting. While you are in your computer, clean it too. Another thing you could try is leaving the side panel off of your computer case. It may be simply too hot inside the computer for your video card to function properly. If that is the case, consider investing in more computer case fans or direct a large box fan toward the inside of your computer.
Jun 14, 2011 | Computers & Internet
How to install a video card,
Find the drivers for your video card that you want to install and get them on the computer before you change cards. Once the driver is on the computer, then you ready to begin. Don't change the drivers to the new one just make sure that its available on your operating system.
Disconnect all cables and power supply from your computer. Press the power button and hold it in to release all energy from the pc. Remove the side cover to all access to the inside of the pc.
Look for the card that has the video connection where you had your monitor connected. Remove the two outside screws on the metal bracket on the back which holds it in place.
Pull the video card out away from the pc towards you. Sometimes you need to wiggle it in order to get it out. Some cards have additional cords which connect other places. The majority that I have seen do not. If your card does, take a permanent marker in order to mark where they connected so that you can remember later.
Insert the new card in the same place where you removed the old one. Put the two screws back in the rear metal plate to keep it in place.
Put the side panel back on. Reconnect all cables and boot it up.
Jan 21, 2011 | eMachines Black ET1352G03w Desktop PC with...
How do you take apart the tower
Disconnect the AC power.
Look at the "back" panel.
You might see thumb-screws that hold the side-panels in place,
or you might see Philips-head ("cross") screws.
Or, you might see plastic "locks" -- slide them 1/4 inch to "unlock" the side-panel, and lift it off.
Or, look at the side-panel -- there may be a "lever" (like a "tab" on the top of a pop-can) that can be lifted to release the side-panel.
Or, older towers had a "one-piece" cover (like an upside-down "U") that needed to be unscrewed, pushed slightly towards the back ot the case, and then vertically lifted off.
Aug 29, 2010 | Gateway GT5220 PC Desktop
Display skcrin black but LED not blinking
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
When starting car/slowing down/steering left or right there is a rattling noise (sounds like a piece of plastic broken off and floating) and also once the windows are rolled up (electronic) if you hold the...
your front drivshafts have cv joints, these have grease in them which quiets them. once the grease dries up they rattle. even more so when turning . you should replace both front cv joints. get rebuilt units to save$$$$
Dec 30, 2009 | 2002 Pontiac Grand Prix
How do I replace the video card on my emachine T6528
To replace the video card:
  1. Make sure everything is unplugged and computer is on a table. (Static is a bad thing)
  2. Remove the left side panel (should be 3 screws on the back)
  3. Panel usually slides back then pops off.
  4. Video card should be about halfway down.
  5. With the computer on it's side, remove the screw holding the old video card in.
  6. Pull the old card out. (might be a tab at the base of card)
  7. Put new card in. (Careful not to push too hard)
  8. Make sure all screws are put back in there proper place.
  9. Reconnect all cables. (Power cable should be last)
  10. Boot up the computer and install the drivers for the new card.
Now where's my $150???? LOL Kind of ridiculous what they charge for simple tasks. I'm not sure, but I think this voids the warranty on emachines?
Mar 11, 2009 | Computers & Internet
MONITOR OR IS IT COMPUTER
Check your video card is seated correctly in the computer.
Disconnect the power and video cable first.
Open the side panel, lift the card up and push it back into the slot with a gentle side to side wiggle as you go.
Also if possible try another video card.
Another thing is to check is if your computer has onboard video. It will be a blue socket on the motherboard at the rear panel where your USB ports etc are.
Mar 31, 2008 | HP Pavilion F1523 15" LCD Monitor
IBM NetVista PC Desktop Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
