Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
My unit does not turn on. It displays FP
It looks like it is locked
  • 1,420 Answers
Hold down on the child lock button for 6 seconds.
Posted on Dec 30, 2008
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
My cs8110 won come on
The standalone unit has the same programing as the salt water unit with the integrated pump. When you see "FP" it is in Filter Pump mode. Simply press the down button for 2 seconds, then the up button for 2 seconds to unlock the pad. Either change your run time or leave it the same and lock the pad (hold the down button for 2 seconds and then press the up button for 2 seconds). After it locks you should see the green working light come on. The reason FP isn't in the manual is that you don't need Filter pump mode on the stand alone unit (I think it should still be in there as it is still possible to get into this mode on accident).
Aug 25, 2010 | Intex Automatic Salt Water System for ...
How do i get the OSD lock to stop flashing on my screen?
mcadams_alic, Mostlikely a problem inside unit. After visiting this web site: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ you may then understand why your unit is acting "strange"!!! Your lcd monitor isn't any different than any other brand in it's basic design and operation. When very strange stuff starts appearing on the screen of any CCFLback-lit lcd monitor the first place all lcd technicians would look will be the monitor's "switch-mode-power-supply!!!! hope this helps. 12fixlouie
Jun 08, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
My monitor keeps turning on and off automatically,...
Guest, Unit not turning "off"!!! Power supply (internal) going into "shutdown" mode.??? Have you been to this site to do some reading!!! It still a good read even after 5 years!!! Still up to this year 2010. Go here http://www.lesliewong.us/blog.2005/05/02/hp-pavilion-f1703-flatpanel-display-blackout-solution/ Remember this! Your monitor isn't any different than any other brand of "cold-cathode-fluorescent-lamp-back-lit lcd monitor in it's basic design and operation! There are seven pages of stuff at the above leslie wong blog. Hope this was of some help. Your monitor may also need new CCFL tubes due to age of unit
12fixlouie
May 21, 2010 | Compaq FP 7317 17" LCD Monitor
Panasonic FP-D250 copier first displays error U16 - install the developer unit - then changes to machine error E04-01. Any suggestons?
hello robertsona from robertsand. e4-01 is fuser warm up. check connections and fuser thermal fuses, as well as the lamps. good luck
Jan 25, 2010 | Panasonic FP-D250F Copier
Error code e30-50 display on fp 7845 panasonic copier
Error code means that the cleaner for the transfer corona unit is not working correctly.
Oct 20, 2009 | Panasonic FP-7845 Black and White Copier
Machine Error e1-20 is being displayed after copier was moved.
That error is related to the laser unit. Check your connectors, they may have vibrated loose during move. These machines have a history of laser units going bad.
Apr 15, 2009 | Panasonic FP-D250F Copier
Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
Apr 09, 2009 | Panasonic FP-7735 Black and White Copier
Unit Won't Cool Or Heat Just Blows Air and Displays FP
fp means freeze protection when gets too cold out unit comes on by itself so pipes dont freeze
Jan 17, 2009 | Amana PTC093B50AJ Electric Heat Air...
Compaq FP 7317 LCD Monitor
Check the buttons on your monitor for possible shorts. Sometimes pressing a sequence of buttons while turning the monitor on will lock the OSD.
Aug 02, 2007 | Compaq FP 7317 17" LCD Monitor
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
91 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
