Radio Communications Logo
Anonymous Posted on May 19, 2012
Cobra 29 lx (new digital display) no power
No power.. plugged it in, the radio went on and off real quick. checked pos. and neg. they were good. plugged pack in, and the radio, again flashed on then off. thought it was a fluke.. dummy me... try it a 3rd time. all I got was a little smoke out of the back of the radio.
  • Anonymous May 20, 2012
    Thanks.. I had the diode was replaced, but come to find out the PCB (printed circuit board) had a burn mark in it. and was unrepairable. Well a $150 radio is now a paper weight. I guess I'll go back to my oldie but a goodie15+ year old cobra 25
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on May 19, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715905
Points
48227
With no power connected read resistance across power leads---likely protect diode just inside back of radio from red power lead is shorted to ground
THE ONLY THING THAT CAUSES THIS IS THE RED AND BLACK GETTING HOOKED UP BACKWARDS---NOTHING ELSE WILL DO IT.
IF YOU READ A DEAD SHORT WITH RADIO NOT HOOKED TO POWER AND POWER SWITCH OFF--THE RADIO GOT RP(reverse polarity).
4 Related Answers
Anonymous
  • 126 Answers
  • Posted on Jan 25, 2008
SOURCE: bub
When you reversed the polarity of the power and negative, if it did not blow the inline fuse, then all you did was burn the protection diode. Sometimes it can do more damage, but usually its just the protection diode that goes. They are a cheap fix and if you have a local cb shop, tell them what you did, and they should, repair it for $10 to $15. If they try to charge more, then they are trying to rip you off. If you don't have a cb shop to go to, and you can unsolder and solder components on a pc board, email me at [email protected] and I will walk you through re-placing the diode. The diode can be purchased at Radioshack.
Dean
Rollin CBs
Mt. Vernon, TX
sharcnet
SHARCNET-USA
  • 2130 Answers
  • Posted on Jan 28, 2008
SOURCE: wired backwards
In many CB's there is an internal diode that is connected across the DC line. When the power is connected correctly, the diode is reversed biased and does not conduct. When the power is swapped, the diode is forward biased and conducts. When that happens, it causes the in-line fuse to blow. Was there an inline fuse in the power leads? I would take the cover off and see if there is a burned diode where the power cord enters the radio. Take a look and see what's burned. Let me know what you find and we'll go from there. If there has been a lot of damage, it may not be worth fixing.
Good Luck,
- Jim
Anonymous
  • Posted on Jan 02, 2009
SOURCE: cobra 25 ltd wx wont power up
You most likely blew a Diode that is back near the power plug.
It is easy to fix the diode but if you continued to apply power you may have damaged other parts including the audio chip.
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Nov 13, 2009
SOURCE: Hello there
Hello there
If you remove the screws that hold the top cover on
and remove the cover look by the front of the unit and you will see a small inline glass fuse (50x250) .
simply remove this fuse and replace it with a new one
also check all of the other fuses that is going to the power cord too ok
I hope that this has helped you out a lot
best regards michael
Testimonial: "wow that did it sorry it took so long to get back to you went to the radio shack and got the fuse now all is well love this radio"
2answers
Why the clock on the cobra 29 lx keep cutting out
jay I am not sure what you mean by the clock cutting out. I enclosed the manual in PDF form look at page 17 and see if this helps. If not ask the question with more detail.
https://www.cobra.com/sites/default/files/manuals/29%20LX.pdf
My cobra 29 lx is saying that my rf gain power failed why is that
you may have burnt the diode that a variable controls or you messed with it and burnt it out.
Cobra 29 Lx turn power up
one of the few radios that won't allow you to turn up. the most you will get is 4.5 watts . if you want power buy yourself a 250 watt liner amp and leave the radio where it is . turn VR 4 up for max modulation and go for it.
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
My cobra 29 lx won't go off of channel 1
what else did you do to mess up this radio.
Cobra 29 LX LCD tuneing
brand new out of the package don't need tuning. just turn up the power a bit to 3.8 - 4 watts and modulation set at 95% and you will be fine.
Just received my new cobra 29 lx cb. When I turn on the power the radio comes on for about 2 seconds then the screen goes blank and all fuctions cease. When the power to the radio is turned off, the screen...
  • Check that power cord up by the tip. It is possible it is a little loos in the tip (that hooks into the radio) Being new it almost has to be related to the power feed.
  • Make sure the fuse you are using is good. Use a 4 amp fuse in there.
  • Make sure you installed all the shoulder washers in your antenna properly or this will cause a short too.
  • Your power supply could be at fault too. Take a multimeter and turn it to DC volts and make sure 13.8 is coming out of it. The power supply could be failing under a load. Have you tried a quick setup in the car? See if sticking the power cord pos to pos and neg to neg on the car battery keeps the radio running better. You don't need to have the antenna hooked up for this just DO NOT key the mike. Just long enough to see if the radio stays on for more than 2 seconds.
  • If you do all this testing and the radio still cuts out then you have a defective unit and it needs to be replaced with a properly running unit.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
3helpful
Hello there My cobra 29 ltd just went dead what do i need to do to fix it i am not real good with these radios best regards righard
Hello there
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
