Question about Lucent PARTNER18 Corded Phone
When receiver is picked up, it opens the wrong line
Whenever we pick up the phone to dial out, the phone always uses the wrong line as its default.
We have two sets of phone lines, one rings only to our desk; while the other lines are for the entire office.
I would appreciate any help if there is a way to change what line the phone uses first.
  • jerry_okler Nov 23, 2008
    I forgot to mention that we are using a Lucent 854 (partner-18) corded phone. ~.~
    President:
  • Lucent Master
  • 860 Answers
. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Posted on Feb 13, 2009
My cordless phone says"Line in Use" - Is this a phone company problem or just the phone
The "Line In Use" should display whenever you pick-up the handset to either dial out or to answer the phone- unless of course, someone else is already on the extension line.
Jul 11, 2014 | Cameras
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
Default line
From your phone press PROGRAM dial 19 ENTER (or STORE) x ENTER (or STORE) then exit by pressing PROGRAM (or EXIT)
If x=0 it's no line If 1 (what you want) it's idle line if it's a 2-digit number 01-36 or the CO button, it's a line, and 3 or INTERCOM is the intercom.
Carl
Jul 03, 2009 | Panasonic KX-T7633 Corded Phone
CANNOT RECEIVE FAXES ALL OF A SUDDEN
Check the phone line with a basic old phone plug it into the fax line do you get a good dial tone, and no noise on line. Also check the phone line call ATT and have them check the number move the fax machine to different plug. power off the wait tens second power on. check the phone line connector.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 31, 2009 | Minolta Office Equipment & Supplies
How do I get "call pickup" to work on a KXTES-824?
Two of the above codes work for me, so let's figure out what you're doing. First of all, did you convert the intercom calls to ringing on all calls? If I have auto answer turned on, I can't pick up anything.
If the phone is ringing, I can use 40 and 41xx to pick it up. I can retrieve a call from hold by dialing 53x where x is the line number on hold (just in case you're trying this with a cordless or single line set).
By default, all extensions are in pickup group 1, but 41xx directed call pickup will always work if the Call pickup deny is properly set as you indicated
Carl
Feb 16, 2009 | Panasonic Lands Phones
How do I change the default line on our phones
restore the factory settings of your mobile byentering the security code of mobile.
Feb 04, 2009 | NorStar M7310 Corded Phone
Lucent partner 18 D phone no sound when I pick up the receiver
The plug going into the phone was not secure. Once it was fully plugged in it was operational. I was making a big problem out of a little one. I thought in cleaning the phone without unplugging it first I somehow messed with the programming. I was wrong. Thanks for trying to help.
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
No dial tone
Sounds like the phone line may be dead, try to put another phone on that line and make sure the phone line is active.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
RCA 25202 Default to Line 2
only when you have call foward from one line to the othe when in use. so lets say line 1 is in use then line 2 will ring but now line 1 is open and its ringing (activate forward ) and will go to line 2 and be able to be picked up.
Mar 07, 2008 | RCA 25202RE3 Corded Phone
Lucent PARTNER18 Corded Phone Logo
187 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
