Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
Jeep CD player problem
CD's usually don't play until about 5 minutes after the vehicle has been running. The radio itself works fine; it's just the CD player. Happens with all CDs. After it starts playing, it's fine unless I change tracks. Then it may be silent for a minute or two then starts playing fine again. After it starts, if I just leave it alone, it'll continue playing w/o problems. The unit is in an '02 Wrangler. Is there a belt or some sort of drive inside the CD unit that could be slipping or otherwise slow to "kick in"? Thanks for any help.
  • 199 Answers
Hi sounds like tye laser needs replacement. try www.carradiospares.co.uk
Regards
Mark
Posted on Nov 25, 2008
CD player works but start delays from 5 minutes to 20 minutes. What could cause that?
Dust inside the cd player could be causing problems.
You need to try playing a cleaning cd and follow the instructions that come with it. You can also spray compressed air to clean out the cd portion of the stereo. You can also try unplugging the unit for 20 minutes and then plug it back in. Make sure your cds are clean and not too scratched up. If the unit is under a year old it may still be under warranty. If this does not resolve the issue you may have to have the unit professionally repaired. If the unit is not worth repairing you may need to buy another unit.
Nov 02, 2015 | JVC UX-T3 Shelf System
How to fix RBQ radio, disconnected battery now radio does not recognize cd
The radio/ cd unit, for your model Jeep, has a built in security code. When disconnecting the the battery it activates the security. The reason for this is to discourage someone stealing the radio, as it renders the unit useless. To re-activate the unit you will have to enter a pin number, which should be supplied with the vehicle when bought from the dealership ( check in your operating manual). If you don't have the pin number, contact your Jeep dealer, who can supply the required pin code. Usually the dealer will re-activate your radio/cd unit free of charge.
Best of luck
May 30, 2014 | 2006 Jeep Wrangler
Amp error message on Pioneer DEH-15UB. Vehicle was jump started twice would this cause this problem? The receiver is not connected to an external amp. The radio/cd player will work for about two minutes...
I just had an "amp error" message display on my Pioneer DEH-15UB and it quit playing. No sound at all. It happened while I was driving my Jeep. When I got home I removed the passenger side speaker from the sound bar and found the previous owner had used a wood screw to hold the wire to the speaker. That screw came into contact with the metal roll bar and caused the error. When I installed ends on the wires the error message cleared itself and now works fine
Sep 17, 2013 | Car Audio & Video
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
Unit keeps beeping and turning itself on and off. Have had this radio for 5 years and never a problem until now.
Hi sasutton,
SIRIUS-Ready radios are usually identified by the SIRIUS dog symbol appearing somewhere on the radio itself. A SIRIUS-Ready radio is a radio that may require the purchase of a SIRIUS tuner in order to be activated.
Every 90 minutes if you do not interact with the player, player display a notice and play a small audible alert to ask if you're still listening to the player. If you're not, the player will shut down after five minutes of the message being up there. If you are there, all you have to do is click the button and you can continue listening. Sirius player do this so that we're not streaming to computers that have no listeners, to maintain optimum performance for active listeners. You are probably not sitting at your computer when this message pops open which is why you get interrupted.
And Thanks.
Mar 19, 2010 | Kenwood Here2Everywhere SIRIUS Radio...
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
2004 Jeep Liberty CD Problem
Sometimes if you shut off the vehicle, then continually press the eject button, while you start it, and continue to press the button, until the radio is on for a minute, it'll work. Other than that, Sorry. Best wishes to you.
Jan 21, 2009 | 2004 Jeep Liberty
Car Audio & Video Logo
180 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
