Question about Goodman Heating & Cooling
Goodman model no. AR42-1 A/C works but heater won't
  • cotillionsor May 11, 2010
    does the condensing unit have a reversing valve to make it a heat pump. the model you gave is for the inside unit that can be straight cool or a heat pump. if it is a heat pump sounds like the rv is not switching into heating. If i know its a heat pump i may be able to advise further.
Heater won't come on
check across tstat wiring on circuit board for 24volts. Test points are R and W. a call for heat should give you 24 volts across those points
Feb 21, 2013 | Goodman Heating & Cooling
Goodman modelgds80703ana flashes 1 code, burners won't light
Check flame sencor is clean and not out of postion check wire conections are tight to this
Jan 10, 2013 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodaman furnace MODel #GMP075-3 work well yesterday and today won`t start, what should I do?
look in the little window for flashing light.count the flashes.take front covers off .on cover is a list of what codes mean.
Dec 24, 2010 | Goodman GMS90703BXA Heater
Furnace will not stay lit
Sounds like a thermocouple, or flame sensor.
Are you skilled on working on appliances of this sort?
I am a goodman dealer and will need your model number.
Nov 26, 2008 | Goodman GMS90703BXA Heater
Led flashes all the time heater won't start
some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
thanks for your help
Nov 24, 2008 | Goodman GMS90703BXA Heater
Service manual for Goodman Heater # PGB036100-1
sounds like that model # is for the A/C coil or its a heat pump air handler. In any event I am not aware of any "repair manual" that is put out by Goodman to the public. They have classes on their equipment but they are geared to the professional serviceman.
If you would like to descrobe the problem, I will try to help you.
Nov 03, 2008 | Goodman GMS90703BXA Heater
No model number...
If this is a split system, look on the side of the furnace, no luck? remove the front panel. look for a little plate or sticker label inside there somewhere. If you are in California, there is a Goodman (A.K.A.) Janitrol, in Ontario CA. They may be able to help. (sorry don't remember phone #)
Dec 27, 2007 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
212 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
