Question about Hunter 52" Ceiling Fan With Light And Remote Control
No power to hunter ceiling fan or light.
I checked breakers ,power line to the fan. I changed the light bulb and turned it on before I put the cover on it worked for a few minutes then went out the fan was off checked it and it was not working either. could it be the fan is dead or the power regulator? I don't know how old it is it came in the house I bought and could be around 7 years old can't find any model number.
  • ED Ingerman Dec 09, 2008
    no power to receiver from remote
    Scholar:
  • 75 Answers
It sounds like either the top part of your remote is bad, or you have a bad connection to it. Have someone that is familiar with electricity (that may be you?) check to see if there is power to the ceiling box, and fan's remote that is ususally in the ceiling box, or just under it in the cover. If you have power there, your remote is failing.
Posted on Dec 21, 2008
How to reset remote and light/fan on hunter model 25739
You can go on-line @ www.hunterfans.com or call 1-800-715-0393. I think you might need a new receiver.
Jul 10, 2015 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan has flickering lights at all times. replaced bulbs and dimmer switches. what could be the problem?
Loose connecton on the receptical (bulb socket). Also in the ligh scoket in the center there is a connector. it may need to to be raised up. DO NOT ATTEMPT TO CHECK WITH POWER ON
KILL POWER AT MAINB BREAKER.
Also check all wire nuts for loose or corroded connections
Sep 08, 2011 | Hunter (25417) Ceiling Fan
All of a sudden the light on our hunter celing fan is flashing like a strobe light
Three possibility for the strobe problem:
1. Loose wire connection. Shut down the circuit breaker, pull down the switch, open the ceiling fan cover and check for any loose wiring connected to the main bulb, If there isnt any, remove the bulb and spray WD-40 or contact cleaner to the receptacle. Replace the bulb.
2. Replace the bulb with a new one. Preferably incandescent or a warm white energy saver.
3. There maybe ghosts fooling around. (I'm kidding)
Hope this helps,
levibit
Dec 18, 2010 | Hunter (25417) Ceiling Fan
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Ceiling fan pull chain connected but does not click on
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
Aug 16, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
We purchased a hunter grand visita and when we turn the light on a the breaker box or the switch plate there is a delayed reaction before the light comes on whats going on?
Here is what hunter technical support says about this.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Mar 01, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Dryers Logo
458 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
