Question about Poulan Pro Chain Saw 46cc 20"
Poulan 3700 will not keep running
I have a poulan3700 and it will not keep running when you give it gas and the choke pushed in(open). When the choke is in mid position, the saw runs great. I just had the carb rebuilt, a new gas filter and a new plug. Puzzled now. I even pulled out the manual and reset the idle, Hi and lo needles but nothing. Could it be a leaking gas line?
  • rmalm57 Nov 30, 2008
    Thank you for all the answers to my problem. I found out the trouble. There is a micro screen in the carb and just the smallest piece of piece of dirt will cause my troubles. Now the saw running like new and as my mechanic said when he tried to fix it, for a 26 year old saw, it looks almost new and I keep it in excellant shape.
  • Anonymous Mar 24, 2014
    I just can't keep it running
    Sergeant:
  • 359 Answers
SONUNDS LIKE WE STILL HAVE A CARB PROBLEM
Posted on Nov 27, 2008
Poulan pro ppb350 weed trimmer stalls when choke is open
-After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
Because the engine need more air to burn the gas.
Good Luck
mai
Jun 06, 2014 | Garden
Bought a Poulan Wild Thing 18" gas chainsaw (P4018WT) secondhand from someone who only bought it to cut down 3 trees. It will not start. I know that it works, as the guy started it up and showed me how...
Don't prime it 6 times.
Prime it once and try starting. Keep trying with one prime.
If that doesn't work, let it sit for a bit. And then prime it two times and try starting again.
If that doesn't work, try priming 3 times.
Then try half-choke with one pull only, and then move choke to run for the second pull.
The saw might have an on-off button
Oct 15, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Engine cuts out when given gas
if theres nothing wrong with it you should close the choke between half and quarter (depends on the engine) and gently rev the engine bit by bit till it warms up, you will find the revs increase with gas to a point but if you give it any more gas it will start to stall and cut out, you have to wait for it to warm up - by keeping the gas at the sweet spot where you get best revs without it cutting out - then slowly increase gas pressure as the engine warms up - you can press it a little bit more bit by bit as the engine warms up and the combustion gets better - eventually you will be able to press the gas fully kin and the engine will just run but sound bogged down or gasping for air - this is when to open the choke to the RUN position (or fully open) --- it's now ready to use.
To restart a hot engine when it's been stopped : 1 Prime the engine - 3 squirts - (you wont flood it - plus it lubricates the top of the cylinder with fresh 2 stroke and is good for the engine) 2 Hold gas a quarter way open 3 Pull cord! as soon as it fires give it an extra squeeze of gas to give the best chance of a clean start.
Jan 15, 2010 | Poulan Garden
Weedeater will not run with choke open.
check your air filter,, and try if do the same thing you have to clean carb. out,, if you dont how just ask me,, thanks hope this help you
Sep 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 3700 will not keep running when you open the choke.
The prob is at the base of the carb. Its sucking air. Be certain to install a new gasket, making sure the both services are very clean. And the mounting bolts tightened equally! Frankster016
Nov 23, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
411 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
