Question about Honeywell Programmable Thermostat Heater
Extra item that is not in the install instuctions
RTH7600D Thermostat - When I took of the wall plate a 1.5'' x1.5'' sticker with silver lines popped out I m not sure if it is a necessary item for the install
  • 1 more comment
  • JayPeeVA Jan 17, 2009
    Yep - same sticker popped out for me. Did you get your's installed with no problem?
  • Anonymous Feb 05, 2009
    The "sticker" could be an anti-shoplifting sensor packed with the unit. I had one in mine, the "silver lines" were in a series of squares (or loops) radiating from the centre of the "sticker". I can't remember if it was in the thermostat housing but it did fall out of the packaging at one point.
  • Anonymous Mar 26, 2014
    does this need a registration plate.just purchased this item, included was pipe, small cement,is there anything else needed.
  • 4 Answers
On page 7 of the installation guide, you are instructed to remove the tab. Not sure what the tab was for......
Posted on May 05, 2009
I have a 2017 Holden Captive LTZ 7 and I am trying to find the paint code sticker. Wher can I find it. I have looke around the door pillars but no paint colour codes. Please advise Thank you
Hi David They normaly have the paint code on one of the stickers or plates. Try under the bonnet on rear fire wall are there any black or silver plates. Also check under the rear floor cover at the rear tailgate.Or in your sevice manual they normaly have a sticker with your vin number etc.paint code should also be there. Good luck.
Aug 26, 2017 | Holden Cars & Trucks
How to revive tarnished silver (Pure or plated)
This tip is very useful for people who deal regularly with silver like coin collectors and Silver plated cuttlery owners. The thing is silver usually gets tarnished when it is in conatct with air for very long periods like years and decades. but this can be reversed pretty easily. Following are the items you will need.
1. tarnished silver
2. Gas burner (household gas stove will do)
3. Any tool or a plier to hold the siver item.
4. Mittens (optional)
Set the gas burner at a high flame and start heating the siver item, heat it until you see that the black areas are starting to turn into a whitish silver colour. Heat it until all areas turn silver colour. Thats pretty much it. Try not to heat the siver to the point where it turns red hot because it will cause it to melt also be extra careful with silver jewellery becuase it can be fragile. and other gems or stones etc may not respond well to this much heat.
Thanx for reading.
on Jul 07, 2011 | RTO Cuttler Hammer Ehd3060 480v 3 Pole...
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
Face plate came off...not sure how to properly adjust...
This is a landlord issue and should be handle by them. Safety/liability issue Good luck. They will have a heating /AC company repair it.
May 16, 2009 | Dayton Electric Heater
Switch a rheem thermostat to a hunter thermostat for heat pump
You can take the front cover off of your programmable thermostat. Unscrew approximately 2 screws that attach the base plate of the thermostat to the wall. Look in the back of the base plate after removing it from the wall to see how the 2 or 3 different colored wires (ex: red, green, black) are hooked up. Make note of this. Remove the wires from the back of the base plate and attach the wires to the same posts that they were connected to on the original base plate you removed. I believe the posts on the back of the base plates are color coded. (Ex: attach green wire to where it says GRN on back of base plate).
Make sure the thermostat that you are replacing and the new thermostat are similiar in shape, otherwise you will have make repairs to cover up a space that may appear around the new thermostat.
May 14, 2009 | Hunter Fan Company 5/1/1 Programmable...
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
147 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
