Question about M&S Systems ZX7000 Bagged Central System Vacuum
I have a 10 year old AirVac central vacuum system that has worked until this morning. As I was using it this morning, and turned it off for about five minutes it would not start again. The tank in the garage (that accepts the dust) sounds like it is just huming not working. What is wrong?
    Scholar:
  • 126 Answers
Sounds like the motor finally siezed on you. Motor is trying to turn but won't thus the hum. Do not allow the vacuum to stay on like this as it may cause a fire. Requires a motor replacement.
Posted on Nov 23, 2008
Vacuum has good suction but will not turn off at the handle or when disconnected from the fitting on the wall
Disconnect the low voltage wires going to the vacuum. If the vacuum stays on you have a bad relay. If the vacuum turns off you have a short in the wire somewhere. The bad news is the relays are not available, however there are some companies that sell external relay control boxes that will bypass your units bad relay.
Jul 20, 2011 | Airvac AVP3000 Bagged Central System...
No suction from wall outlet. Power to powerhead. Breaker has not been tripped. Manual mode works on cannister in garage. AirVac VM458.
I had the same exact problem and it took about 4 months to find out the problem. I had a paper clip stuck to one of the orifice in the hall way of my house and that is what I had experienced. The other thing is to check the entire tube system because maybe a mouse or rat has chewed into it. It has all to do with the electrical wire throughout the system. Good Luck
Jan 06, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
I just inherited an AirVac AV400. It won't turn on. What do I try? GrampaBigJohn
there is a reset button on it some where near the power switch so I would look for it as it most likely is that simple. good luck!
Oct 07, 2010 | M&S Systems Bagless Central Vacuum
Easy Flo Central vacuum will still work at about
Yes you can easily test for a clog, and a crack for that matter.
to test for a clog push a dry garden hose through the entire system until it comes out at the other end.
to test for a crack, Disconnect the pipe that comes from the house to the central vac unit. Turn on the unit and put your hand over the opening directly at the central vac unit.(Using the utility inlet at the unit will not accomplish the same thing.)
  • Step 2 If your suction is good, then reconnect the tubing and turn on the switch at the unit. If there is no switch, plug your central vacuum hose into one of your inlets to start the system. Then have someone completely seal the hose with their hand. While the unit is running go to the exhaust. With everything closed you should feel almost nothing coming from the exhaust. If you feel very little exhaust, then you do not have a leak
  • Jun 06, 2009 | Easy Flo EF2300 Central System Vacuum
    AirVac ZX6000 won't turn off!
    There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
    Apr 21, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
    Central vac pipe stuffed with pine needles from XMAS!
    You can use a Tornado Cloth to clean out your central vacuum piping. Its the simplest and most cost-effective maintenance routine you can do.
    You can purchase them from here
    http://www.thinkvacuums.com/new.htm#Maintenance
    Jan 18, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
    De clogging pipes
    You can try these as long as you have some airflow. http://builtinvacuum.com/tornado-power/ If you have no suction or airflow from one particular inlet, you can reverse the main unit by hooking the inlet piping to the exhaust of the unit. Tape all other inlets closed, and turn the unit on. This should blow the clog out through the inlet door. (be prepared for a some mess with newspaper or something else to protect your floor in front of the inlet) If you still can't unclog it, borrow a portable canister vacuum or a shop vac and try to **** the clog from the inlet while you blow from the other end with your central unit. Good Luck!!
    Sep 08, 2008 | M&S Systems AirVac AVP1200 Platinum Series...
    M&S Systems ZX7000 Bagged Central System Vacuum Logo
    178 people viewed this question
    Top M&S Systems Vacuums Experts
    Thatvacguy.com
    Electric Hospital
    Electric Hospital
    Are you a M&S Systems Vacuum Expert? Answer questions, earn points and help others
