Question about Gaggia Classic Espresso Machine
No coffee, only steam on gaggia synchrony
The buttons for all the coffee commands do not work-
The machine will steam and that's all.
Is there a fuse problem?
  • 32 Answers
The solenoid valve is probably stuck (also called a three way valve). I wrote about how I fixed mine in another post. Here's a link. From there you'll find links to where you can buy a new solenoid if that's what you need. Good luck.
Posted on Aug 07, 2009
I was descaling my machine (gaggia synchrony- 3 years old). After it ran thru the first cycle & I refilled it I can't get it to heat up again & it shows a light indicating there's no water- when...
Make sure that the sensor in the water tank has not stuck IIRC it's on the right hand side as you look at the machine from the front. Then run some water through the steam nozzle, it could just be that following the descale there is no water in the boiler and you just need to fill it as you did when it was new.
Hope this helps.
Aug 17, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
Jan 04, 2010 | Gaggia Syncrony Compact Coffee...
Frother doesn't steam strong enough
Frother might be blocked, descale unit or use a paperclip to clear the end of the frother, or depending on the model there is a small teflon piece in the top end of the frother, remove that and discard.
Dec 11, 2009 | Gaggia Synchrony 90101 Espresso Machine
I need to replac steam valve for gaggia syncrony compact, where can I get the parts?
I get parts for my Synchrony from Cerini.
There are a couple of different stram valves. Call them to get the right one.
Nov 14, 2009 | Gaggia Syncrony Compact Digital Espresso...
I have an old larger version of the Digital Synchrony and have a message that says 'hot water ventilate'. I have tried to run hot water through the machine using the hot water tap/button but nothing...
Check the end of the steam spout that may be blocked, use a paperclip to clear. If you still get the same result then the machine needs to be descaled.
Oct 08, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
I have a Gaggia Synchrony compact. I recently decalsified it and it stopped working. The low water light is on and nothing works except, for the water pump. It will flow only cold water through the steam...
If it leaks from the steam wand then you need to get a new steam valve assembly. For the heat you will have to open the machine it is possible that the steam boiler is damaged or that the thermostat on there is bad, use an ohmsmeter to check thermostats and element. There are 2 screws in the grinder, 2 behind the water tank and about 2 or 3 in the front behind the door.
Jun 09, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Doesn't power up
Same problem here, working one minute, lights out the next. No signs of life. Hoping there is a fuse or breaker somewhere.
May 12, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Classic Espresso Machine Logo
293 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
