Question about Dell Inspiron 1501 Notebook
GIGABYTE TV card does not function on my Dell Inspiron 1501
I recently purchased a GIGABYTE digital TV dongle U7000 USB 2.0 in Australia. I was assured that it would work anywhere in the world. When I tried to install it on my Dell Inspiron 1501, at home in Ireland, it seemed only to part install. I am able to access the PowerCinema page but I get message saying that there is no TV tuner card loaded. I am wondering does my notebook require some additional piece of software.
I would be very grateful for any asistance.
Many thanks,
Tommy McGurrell,
Dublin
  • 4 more comments
  • tommymcgurre Dec 05, 2008
    Thanks for tr speedy response. Am presently downloading U7000 driver. Will supply comment when I test result of download.
    Thanks,
    Tommy
  • tommymcgurre Dec 11, 2008
    As suggested , I downloaded the file from the link provided. However when I try to install it I get a message " Installshield Wizard completed.....the Wizard was interrupted before the Gigabyte U7000 TV card could be completely installed" I have tried this a few times with the same result.
    tommymcgurre
  • tommymcgurre Dec 28, 2008
    The TV card in question is a Gigabyte U7000 USB 2.0 which was bought specificallyfor a laptop!
  • tommymcgurre Dec 30, 2008
    As suggested, I uninstalled the software and tried again to install it using the CD provided with the Gigabyte Dongle. I get a message "Unknown hardware" and can only install "TV player"; I cannot install either "TV card" driver or "Remote control" driver. I had previously uninstalled and attempted to download the drivers from the link provided by your expert; but I ended up with an "Install wizard " problem as previously described.
  • tommymcgurre Jan 03, 2009
    I tried downloading the driver, but cannot access it from the link provided.
    I feel trustrated at the moment because I posted a comment in relation to a suggested solution on 30 December and today 3 Jan, yet the reply to my comments was exactly the same, and both dated 28 Dec ???
  • Dell Master
  • 19,396 Answers
Also remember to unplug the USB TV card before reinstalling the driver software.
Plug back the card only after installing drivers, or when prompted by setup wizard.
Posted on Dec 29, 2008
    Master:
  • 416 Answers
Because Ireland has different broadcast system standard called SECAM. In Australia if you purchased it where they use PAL, so TV card was adopted for reception of TV broadcast in PAL. Without standards conversion, it is impossible to view a video/TV program without first converting them to appropriate standard.
More information you might get here
http://www.high-techproductions.com/pal,ntsc.htm
Most probably you need to get PAL-SECAM converter for instance here.
http://www.converters.tv/signals/pal_to_secam.html
Good Luck
Posted on Dec 28, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, two ideas to consider:
  • prior to installing the driver/software, temporarily disable the laptop's antivirus and/or firewall;
  • connect only the USB Tuner when instructed by the installation program or after a reboot;
  • it may be necessary to update or even rollback the laptop's drivers for the USB root hub.
Good luck and Thank you for using FixYa.
  • 679 Answers
If your card is running the american tv version it is called NTSC
The european and your country as england uses PAL,they are not interchangable, unless it specifically says it will plat both PAL,and NTSC, so if it wasn't compatable to both signale then you are out of luck, also search your hard drive for fragments that are not allowing a reinstall and reboot prior to re installing, it sounds like it's incompatable to me andyou got one of those salesmen who just lie to make the sale of just yes you to death, Gym
  • George Bill
    George Bill Dec 30, 2008
    try shutting your virus and spyware off and disconnect from the internet while doing the install, then if you still can't get it in, try in safe mode, by taping the F8 key while rebooting, prior to the set booting up
  • 4,472 Answers
Http://gigabyte-u7000-tv-card-driver.software.informer.com/
You will need to download the driver from this page and install it then you will have your tv tuner card installed. If you need further assistance please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    Sergeant:
    Champion:
  • 275 Answers
First of all i dont think there should be any issue with the compatibility ... try to uninstall it and install it again ...than try again
that should work
Posted on Dec 05, 2008
    Genius:
  • 1,269 Answers
TV tuner card is not a software. Its another piece of hardware. There are two types of TV tuner card. One is USB type and the other one is a PCI type. You need to have a USB type tv tuner card since you are using a laptop.
    President:
  • 2,110 Answers
  • Sibananda Jena
    Sibananda Jena Dec 28, 2008
    in theCapture Device allows you to select your TV capture device.
    In the Capture Source option, select if your TV receives signals from
    Cable, Antenna, Composite, or S-Video.
    The Region option allows you to select the country or region where
    your cable provider is located.
    Audio allows you to set your audio output. Options depend on your
    TV's signal type, but may include Mono, Stereo, or the enhanced
    signals Dual A, Dual B, or Dual AB that augment the main audio,
    provide an audio translation, or offer other information.
    Set the Enable Time-Shifting option to Yes to be able to watch
    instant replays
  • Sibananda Jena
    Sibananda Jena Jan 03, 2009
How do I setup wireless N technology on Dell Inspiron 560 Intel Core 2 Duo
Try following the instructions in the quick start guide. That is what it is for after all. The card goes inside the case, look on the back and see if there is anywhere to fit the antenna. If there isn't you will need to buy a wireless card(it doesn't have to be Dell or even a card- a USB wireless dongle will do the same job and is easier to fit and set up.
Jan 12, 2013 | Dell Computers & Internet
I havent have a blootooth on my laptop
Can you please elaborate the issue please.
You are not able to use you btooth now or it was never there in the computer?
Which operating system are you using?
Is it a laptop or desktop?
Admin
HNetworking.com
Feb 03, 2011 | Dell Inspiron 1501 Notebook
Does my 1550 have blue tooth
Here's a rundown of what you don't get in the Inspiron 1501 that comes standard with the Inspiron 1505, I am assuming yo did a typo with the 1550
  • No dedicated media buttons on the front
  • No Dell Media Direct software feature
  • No FireWire port
  • No S-Video port
  • 3-in-1 card reader instead of 5-in-1
  • No internal Bluetooth option
But if yours is the 1501 then just buy a $7 blue tooth doogle that slots into your usb then your bluetooth problem is solved.
Nov 28, 2009 | Dell Inspiron 1501 Notebook
Is there a software that you can download to make your computer have bluetooth
You need to have the appropriate hardware in order to use bluetooth. You cannot download the software and assume it will work.
Jun 25, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 key stuck but not.
The most valuable test you can perform now is to buy or borrow a usb keyboard. If the problem persists with the external keyboard then it is reasonable to conclude that the problem is software based. If the problem disappears then, if the unit is still under warranty send it in ASAP.
I have experienced 2 notebook keyboard hardware failures over the past 5 years.If you are outside of warranty, you may choose to use a usb keyboard as more more cost effective solution.
If the problem is software based, have you attempted to reinstall your software in a stepwise manner checking for the problems recreatability?
Jan 19, 2009 | Dell Inspiron 1501 Notebook
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Laptop can't find Bluetooth software for dongle
gougher01,
Thanks for following up with me. It's taken a while, but after 10 mins of searching in the usual XP 'Trying to locate software' from the internet, it has found and installed the necessary drivers and the dongle indicates its ready for use. Have yet to test it. Key msg for outers is to give the net search time as nothing happens for at least 10 mins of the search, so you can be tempted to give up, as I did on first attempt. Thanks. Trevor (Bluetooth dongle has 'Bluetooth' as its TM, otherwise I' not clear as to manufacturer as no docs came with it.)
Dec 22, 2008 | Dell Inspiron 1501 Notebook
BLUETOOTH
There is No Internal Bluetooth Option On This Model.
If you want Bluetooth, You,ll have to purchase A seperate Bluetooth Dongle.
There Is A Wifi Built In. ( To enable This you,d Press fn and F2 On The Keyboard )
Hope This helps.
Mike @ Compurepair.
Sep 17, 2008 | Dell Inspiron 1501 Notebook
Enable my dell inspiron 1501 bluetooth
I looked over the system configurations for the Inspiron 1501, and it doesn't have Bluetooth capabilities built into it. The 1520 series does, but not the 1501. The only way you're going to be able to add Bluetooth technology is to purchase a Bluetooth usb adapter. Here's a link to the 1501 manuals if you would like to look over them.
http://support.dell.com/support/edocs/systems/ins1501/en/index.htm
Sep 02, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
119 people viewed this question
Alun Cox
