Question about RCA P46920BL 46" Rear Projection Television
Setting convergence using service mode on the tv.
The AC fuse on my TV blew out a few nights ago. I replaced the fuse and now the top and bottom of the screen are bowed inward and the colors are off as well. how do i use the onboard service mode to fix this problem?
  • RCA Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the buttsetting convergence using service mode on the tv. - 69189a5.pngails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
RCA 52" Projection HDTV Model# R52WH74YX60
I WAS TOLD BY 2 TV SERVICE TECH THAT IT IS THE CONVERGENCE BOARD MY TV IS DOING THE SAME THING I HAVE ORDER THE PART TO FIND OUT IF THEY ARE CORRECT.
Sep 04, 2009 | RCA HD50LPW175 50" HDTV
Picture in 3d without the 3d glasses
your convergence settings are moved and they need to be adjusted and if you adjust and still have the problem then its the problem of convergence STK ICS and they need to be replaced.
for adjusting the convergence please click this link this will help you how to adjust the red, blue and green settings in your tv.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
for replacing the convergence STKics just click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
feel free for further assistance.
thanks.
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Image completely distorted
You will need the service manual to locate the blown resistors and or the circuit protectors in this TV set. If you know how to read the service manual, the schematic, and trace the circuit, know how to use and ohm meter and a volt meter, I am sure we can fix this set together. Let me know with an e-mail address so I can save you 30 bucks for the service manual. Good Luck
Jul 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Convergence
Replace (2) STK392-150s these are your convergence ics.
Nov 12, 2007 | RCA P52928 52" Rear Projection Television
Sony KP_43T70
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Sep 13, 2007 | Sony KP-43T70 43" Rear Projection...
Convergence/menu problem
The convergence power supply has failed,replacing the 215530 reg.on this board will restore the convergence menu,this board is on the right side facing the back or the set mounted on the black plastic above the board with the 6 heat sinks on it
Mar 01, 2007 | RCA P52930BL 52" Rear Projection...
Picture off on screen vertically-Black at top of screen and pic below bottom of screen
Your TV most likely has one or more possible problems.
  • Screen looks 3D
Oct 04, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
