B&O 7007 beocenter. need belts for tape deck,
Hi dont no if you can help, but im a bit of an audio enthusiast and going to the tip on satday and pick'd up a b&o beocenter 7007 for four pound! great, quickly putting it on the back seat of the car. got it home and went over it, great way how it opens. then pluged it in and to my suprise it lite up. the display counter has two LED out, there are no belts on the tape deck, and no needle.
Just would like to no if it is worth fixing it up, and how much for the bits.
i was suprised how heavy it was. i currently have a luxman L100 which i love and dont think i would change, so will proberley sell it on ebay. i would just love to get it to its formal glory
if anyone can help
Regards Lee
  • 122 Answers
Belts are long since discontinued.cartridges are expensive look for mmc20s mmc20e mmc20en
Posted on Jan 22, 2010
How do i remove platter on Beocenter 7007
From the Beocenter 7007 manual:
"If you ever want to remove the platter, lift the record spindle and then insert your fingers under the rim of the platter."
Sep 19, 2014 | Audio Players & Recorders
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 7002 tape deck starts and clicks off within 2 sec.
If the take-up spool (r/h) doesnt turn the autostop will activate.Both these spools get clogged with old grease with age, remove and clean/regrease them,check all belts while apart and replace any limp ones.Removing the tape deck requires some knowledge.
May 09, 2010 | Bang and Olufsen Beosound 2000 Shelf...
The sliding cover for the tape player sometimes gets stuck when opening.
if we are talking beocenter 9000/8000/9300/8500/9500 replace belt,clean and lube door guide rails
Oct 19, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Pioneer CD deck Receiver XR P250. Neither of the two tapes work. They dont go round.
Hi John
This is something I can tell you that you can sort out yourself with a little bit of mechanical aptitude and a couple of screwdrivers.
FIRST turn the power off to the unit.
If you pop the lid off the unit, you will see that the capstan drive belts to the tape decks mechanism have failed, Either turned to back muck like windscreen sealant, or just broken and dropped off. The belts (each deck has one) will need to be replaced. The part number for the belt(according to my records) is REB1272 You should still be able to get them from Pioneer spares directly in your country. Let me know where you are and I can get some better information to you.
good luck. Happy to assist you further and answer any questions you may have.
regards
robotek
Nov 06, 2008 | Audio Players & Recorders
I would like a new stylus for Beocenter 2200
the stylus is most likely integral to the head...there are no alternate supplyers im aware of.
for my beocenter 1800 b&o asked for 250euro for a replacement.
next move i made was to buy a cheapo generic needle, scavenge the tip - wich was actually hollow, and ram im it on the broken renmant of the original one....not very hi-fi, but worked noiselessly.
Jul 23, 2008 | Audio Players & Recorders
Broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Feb 07, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Tape deck clicks off won't play. Slows down and stops when rewinding.
Really simple one this. You have a slipping belt. Don't try to use any more tapes in it, you end up chewing them up. I change all my belts in my decks every 2 years due to the extreme heat we have here. Unless you know how to strip the unit and can get hold of the correct belt I'm afraid it's a repair shop job. BMW To give you some idea of price I charge $50 for a complete service, alignment and belt change.
Nov 17, 2005 | Panasonic SC-AK20 Shelf System
282 people viewed this question
 Grubhead
Grubhead
