Question about Poulan Pro Chain Saw 46cc 20"
Poulan 3700 will not keep running when you open the choke.
I just had the carb rebuilt, a new gas filter and plug but when you push in the choke in the run position and give it gas, it dies. Will run great when the choke is in the mid position.
    Sergeant:
  • 314 Answers
The prob is at the base of the carb. Its sucking air. Be certain to install a new gasket, making sure the both services are very clean. And the mounting bolts tightened equally! Frankster016
Posted on Nov 24, 2008
18.5 briggs intek vtwin only runs choke on only
Make sure the fuel jet is clean. Its easy to miss when cleaning the carb. Ive seen a lot of dirty fuel jets that once I clean them out run like new after.
Sep 25, 2014 | Garden
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Engine starts runs well but after 45 minutes or so will die . I can choke as it starts to die and engine will continue running.When it dies will restart easily.Ihave replaced gas filter ,cleaned tank,new...
Carb. needs to be rebuilt. If your choking the engine it to keep the alive and you've cleaned and replaced everything else, I would recommend carb. overhaul.
Sep 23, 2013 | Garden
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Weedeater will not run with choke open.
check your air filter,, and try if do the same thing you have to clean carb. out,, if you dont how just ask me,, thanks hope this help you
Sep 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
SONUNDS LIKE WE STILL HAVE A CARB PROBLEM
Nov 23, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
253 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
