Question about GE Profile 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel
Lower element on GE Profile electric convection oven went out
I saw my lower element in my oven crackle & then burn out last night while making a pre Thanksgiving dinner. Is it easy to replace? I need to do something quick because Thanksgiving is only 4 days away! The Model # as best as I can make out is J-TP17WOV2WW
  • 1,543 Answers
Although this is an easy repair, the element is not a real common one so many service / parts stores may not have the WB44K5018 in stock. Make sure to get on finding one fast to make T day go smoothly. Here in the midwest I use C.E. Sundberg for a lot of my parts, as they have a good stock and are fast. (they have this part on hand at their main branch in Chicago and at Omaha, Fargo, and St. Louis Park (MPLS). The repair is essentially: Turn off power. Remove two 1/4 inch hex head screws. Pull element forward a couple inches into oven cavity to access the electrical terminals. Remove push on wires from old element. Install new element. One of the easier repairs.
Posted on Nov 23, 2008
After self cleaning now won't heat up
Self cleaning superheats the oven to burn off the dirt to ash. Unfortunately it can also burn out elements and the wires that are attached to the elements.
Disconnect again and check the timed oven settings. If no go, you need a service engineer.
Apr 16, 2016 | GE Profile JT952 Electric Double Oven
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
GE Profile convection with light bulb burning out
Multiple possibilities.
  • Being used as a night lite. (continuous use)
  • Not using a light bulb designed for use in a oven.
  • Inexpensive bulb. (very low lamp hour rating).
  • Oven door slamming.
  • Over voltage condition.
  • (My favorite) Light bulb swapping Gnomes.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel Logo
384 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
