Question about Air Tools & Compressors
Where to add oil on a sears 2150 pressure washer
I picked up this pressure washer in a garage sale and it didn't come with a manual. Where do I add the oil,what type and where can I find a copy of the manual?
    Problem Solver:
  • 7 Answers
I'm not sure weather you are adding oil to the engine or not. Most Briggs engines have a dip stick housed on the side of the engine. That's where you check oil and also where you add oil. Same hole.
Be cautious though not to over fill the crank case.
good luck,
Posted on Nov 24, 2008
Garage door touches floor then goes back up unintentionally. After reading manual, I adjusted the down limit but it didn't correct the problem.
You need to turn the down limit adjustment in the opposite direction of the arrow printed on the motor housing cover.
Sep 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I just received a 4 cycle weed trimmer from Sears. They told me it would not have a manual. I have to add oil but, it does not tell me what type of oil to use. How hard would it have been to put that...
you should be able to go to look for the heading Owners Manuals and either type in your Model number or just look through untill you find it then down load it
Or just go to your local lawn equipment sales/fixit shop and theyall tell you
Jul 26, 2011 | Garden
We got a Marshall 82 digital blood pressure monitor at a garage sale, but it didn't come with the manual. And we really aren't sure how to work it????
We got a Marshall mb02 digital blood pressure monitor, but it didn't come with the manual. And we really aren't sure how to work it????
Jun 07, 2011 | Marshall Professional Aneroid...
I have a 93' Toyota pick up with a 3.0 v6 EFI.I
Check your oil, I borrowed my mother in laws truck like this it had no oil pressure well it didn't have any oil. If you have oil you have a weak oil pump or your oil passages might be clogged up. You could also try running a thicker oil like a 10-40 instead of a 10w-30, or maybe add some oil honey something like that. Hope it's just low on oil that would be the easiest fix.
May 16, 2011 | 1993 Toyota Pickup
Where do you add the oil on a DeWalt 3100psi pressure washer?
Hi and welcome to FixYa, I am Kelly
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Thanks for choosing FixYa,
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
Don't have a maunual, bought this from garage sale...need one...also already moved the machine without the shipping brackets...any worry of damage? have not used yet
See the following site for on line manuals for Sears products.
Click on the Manuals tab, enter the model number and you should be able to download a PDF version of the manual.
Since you've already moved it, the only thing to do is to try it.
Aug 22, 2010 | Kenmore 44832 Front Load Washer
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
if using a good quality 2 stroke oil brand
mix it @ ratio 50:1 that is 100 mils of oil per 5 litres of petrol
or on a 1 litre basis it would be 20 mils of oil per litre
but !!!! if you are using generic 2 stroke oil from a garage
run it on 25:1 mix that is 40 mils of oil per litre of petrol
be sure to put required qty of in clean container 1st then add petrol qty to the can and give good shake , then fill your saw
cheers hope it helps
Jul 31, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel oil mixture
use a 32:1 mixture which is approx 4oz 2cycle oil to 1 gal of gas. you can also add an ounce or two of of a fuel sys cleaner to your fuel mixture for a good cleaning of the carb to remove any gum or varnish build up which could cause poor engine performance. hope this helps you
Aug 08, 2009 | Homelite Garden
Craftsman 4 hp 2150 psi pressure washer wont start
Go to ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Jan 10, 2009 | Karcher 2500 PSI Pressure Washer
Air Tools & Compressors Logo
234 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
