Question about Whirlpool LSR7333 Top Load Washer
Whirlpool washer that will keep filling with water
Model LSR7233DQO
  • Whirlpool Master
  • 3,463 Answers
Hi If it is still filling after being turned off, then you have a faulty inlet valve, if it is whilst it is still working, then it is probably a faulty water level switch, or a blockage in the hose to the switch
Posted on Nov 23, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
I have a whirpool LSR7233DQO model top loader washing machine, a month ago it stopped agitating, now it will not spin at all on the spin cycle. It actually sounds like there is movement in the bade of the...
Sometimes the switch goes out (that little thing you held your finger on to keep it running). That's ~$20 to fix. If the washer runs, fills with water and won't spin once it reaches the spin cycle you probably need a new motor.
Feb 05, 2014 | Washing Machines
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool lsr7233dqo will not stop filling up in wash and rinse cycle, cold water does not shut off compleatly.
Check the clear plastic hose that runs from the pressure sensor to the bottom of the drum. If it is not secured away from the drum or other parts of the washer it'll rub against the metal and wear a hole in the tube. It only needs a tiny hole and the hose won't hold pressure and tell the sensor that the tub is filled. One way to test is to take the host off completely and blow into it while stoppering the other end. You'll probably hear the leak but if you don't you can drape the hose in water and the bubbles will tell you where the leak is. Either replace the hose or cut the hose at the hole and buy an coupling that you can insert between both ends. Just make sure that it is airtight. If the hose is good...the presure sensor itself may be bad.
Dec 26, 2009 | Whirlpool Washing Machines
My Whirlpool front load washer keeps filling with water when off.
turn off water supply taps when not using machine
Dec 21, 2009 | Kitchen Ranges
Water keeps filling the washer
If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WHIRLPOOL MODEL LSR7233DQO WILL NOT STOP FILLING
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Washing Machines
Washer is leaving blue stains on clothes after washing.
ok kenna ,,open lid and grasp the fabric dispencer from the top and pull straight up,,it well come off,,,next run it under hot water for a few minutes,,now get some bleach and fill dispencer and let soak over night than flush again with hot water,,that should free it..to get your manual go to servicematters.com..im onthejob
Oct 19, 2008 | Whirlpool LSR7333 Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
94 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
