Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Outside unit freezing over
We have an Amana 14,000 btu unit Model # PTH153B35AM heatpump/AC unit. It was purchased new and installed last year. We have it heating a 700 square feet cabin. The outdoor temp. was in the teens. The outside unit is freezing over. The unit is still putting out heat but runs constantly. Just concerned why it is freezing over outside and what we can do to prevent this from happening.
  • 26 Answers
Check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Posted on Nov 25, 2008
Purchase an friedrich 1400 btu last year from pc richards was working well until last night when I turned it on the light came on heard it humming and then it turn off my surge. What could be wrong with...
Take the surge supressor off the unit, or it better be a good one, and its best not to have it plugged into any thing, just straight into the plug in, and your unit is 14,000 btus
Jul 04, 2011 | Friedrich Heating & Cooling
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="" title="Flow units converter page on - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
I am getting alot of water leaking out of the unit.
I live with my husband and three sons in a house that we almost never succeed in cooling enough every summer. But a few months back, my uncle mentioned that he had recently purchased a new model of air conditioner by Plasma Cool called Plasma Cool Portable PC-14E that required no draining and came equipped with technology to remove most of the humidity from the air. We checked this ac out at his home, and the next thing we did was researched all the no drain acs with evaporative booster out there in the market to see if there was anything better than the one my uncle had. But the only one that met our needs and budget was Plasma Cool Portable PC-14E. At 14,000 BTU, this ac is 40-50% more powerful than similar acs in the market and covers upto 500 sq. ft. Look for this product on which lays out the features and specifications in easy and comprehensible fashion without coming across as trying too hard to sell you the product. We just finished the 30 day trial period, and now own the ac. We are very satisfied and are considering purchasing another unit soon.
Jun 25, 2009 | Frigidaire FAP094P1Z Portable Air...
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Leaking evaporator home ac NEW Amana unit
Happy to assist you!
Why are you doing it?
You have a new warranty, call service and let them correct it!
You need to call service !!!!!!!!!!!!!
Aug 29, 2008 | Amana Heating & Cooling
Moldy smell to air
I have a maytag ac unit that kept smelling moldy. We tried spraying with antifungal, only helped for a short time. I took the unit (ac unit slides out of window case) outside and carefully removed screws only to discover the fan was covered in mold!!!! Oh my what a horrible discovery! I washed the fan blades with bleach and water mix. I completely and carefully washed and wiped down the air conditioner careful around the control box. Then I let the unit sit outside in the sun untill completel dry. Good bye mold and fresh clean cool ac!! I will do this each year now that I saw that ugly mold!! That is definetly a health hazard! I would reccommend you either thouroughly clean your unit or pay someone to do it or get a new unit right away!! Don't use that moldy unit another day!! Good Luck!
Oct 03, 2006 | Mitsubishi Mr. Slim MXZ30TN Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
515 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
