Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Intermediate whistle I turned on my furnace at camp today and it has an intermediate whistle.
  • Lee LaVanchard Dec 31, 2008
    We do have the same problem. Our heater is propane. Model #1004F. Our heater was new last year, and the problem began almost immediately, so I am can't believe it would immediately be dirty, dusty? Our heater is vented.
    Novelist:
  • 126 Answers
That kind of noise is coming from the air or exhaust side of the unit. Check the end of your flue pipe for frost or ice. Make sure the pipes from the flue to the heater are in the correct position.
Tom Hawkins
hawkins111@gci.net
Posted on Jan 11, 2009
  • 27 Answers
Sounds like you have dust or spider web in one of the burner tubes. turn power off to unit and clean the burners especiaally by the nossles
Posted on Nov 26, 2008
How to replace steering wheel position sensor on a 2006 Cadillac DTS?
Manual Steering Column with JL4) or
Steering Wheel Position Sensor Replacement (Power Steering Column with JL4) ?
Preliminary Procedure Remove the intermediate steering shaft. Refer to Intermediate Steering Shaft Replacement .
Steering Angle Sensor Adapter
Procedure Disconnect any electrical connectors as needed.
Tip
If reusing, secure the old steering wheel position sensor before removing it for proper alignment upon reinstallation. Refer to Steering Wheel Position Sensor Centering .
Callout
Component Name
Notice: Secure the steering wheel utilizing a strap to prevent rotation. Locking of the steering column will prevent damage and a possible malfunction of the SIR system. The steering wheel must be secured in position before disconnecting the following components:
The steering column
The intermediate shaft
The steering gear
After disconnecting these components, do not move the front tires and wheels. Failure to follow these procedures may cause improper alignment of some components during installation and result in possible damage to the SIR coil.
Preliminary Procedure Remove the steering column. Refer to Steering Column Replacement .
Intermediate Steering Shaft Bolt
Procedure Remove the steering column boot seal in order to access the intermediate steering shaft bolt.
Intermediate Steering Shaft Nut
Notice: Refer to Fastener Notice in the Preface section.
Tighten
47 N?·m (35 lb ft)
Tip
If necessary, scribe location marks between the intermediate steering shaft and the steering column and the intermediate steering shaft and the steering gear to mark their alignment before removing.
If replacing the intermediate steering shaft, transfer any scribe marks from the old one to the new one.
Callout
Component Name
The steering column
The steering gear
Preliminary Procedures
  1. Remove the left side instrument panel insulator panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
  2. Remove the driver knee bolster. Refer to Driver Knee Bolster Replacement .
  3. Disconnect the intermediate steering shaft from the steering gear. Refer to Steering Gear Replacement .
Steering Column Nut (Qty: 4)
Notice: Refer to Title not found in the Preface section.
Tighten
25 N?·m (18 lb ft)
Steering Column
Procedure
  • Disconnect any electrical connectors as needed.
  • If equipped with AN3, disconnect the automatic transmission range selector cable. Refer to Automatic Transmission Range Selector Cable Replacement - Column .
  • Transfer any parts as needed.
  • Sep 12, 2015 | Cadillac Cars & Trucks
    I have a Panasonic Workio DPC 262 I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
    Intermediate Transfer Belt Length Detection Error Causes 1. Belt Initial Point Detection Sensor is defective. 2. Belt Initial Point Detection Sensor connector is disconnected. 3. EC PCB connector is disconnected. 4. EC PCB is defective. 5. Intermediate Transfer Belt is defective. 6. Intermediate Transfer Belt Motor is defective. 7. Intermediate Transfer Belt Motor Connector is disconnected.
    Dec 22, 2014 | Panasonic Office Equipment & Supplies
    Economists include only final goods in measuring GDP for a particular year because if intermediate goods were
    counted, then multiple counting would occur.
    The dollar value of final goods includes the dollar value of intermediate goods. If intermediate goods were counted, then multiple counting would occur. The value of steel used in the production of automobiles (an intermediate good) is included in the price of the final product (the automobile).
    Jun 22, 2012 | Mcgraw-Hill Computers & Internet
    How 2 replace intermediate steering shaft,Healp!!
    The front wheels of the vehicle must be maintained in the straight ahead position and the steering column must be in the LOCK position before disconnecting the steering column or intermediate shaft. Failure to follow these procedures will cause improper alignment of some components during installation and result in damage to the SIR coil assembly. 1. Raise and support the vehicle. 2. Remove the stabilizer shaft. 3. Remove the tie rod ends from the steering knuckles. Caution: Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control which could result in personal injury. Notice: The front wheels of the vehicle must be maintained in the straight ahead position and the steering column must be in the LOCK position before disconnecting the steering column or intermediate shaft. Failure to follow these procedures will cause improper alignment of some components during installation and result in damage to the SIR coil assembly. 4. Disconnect the steering intermediate shaft from the steering gear.
    Dec 12, 2010 | 2000 Pontiac Grand Prix
    After 5 or 6 copies taken an error E000070-0202 and E000070-0101 will occured. what is the problem
    E070 there is an error in the detection of ITB home position
    00xx The home position of the intermediate transfer belt is not detected within
    a specific period of time .
    The ITB HP sensor is faulty.
    Turn off the main power, and check the DC controller PCB and the
    ITB HP sensor; then, turn on the main power.
    01xx The period of time between when the home position of the intermediate
    transfer belt is detected and the next home position is detected is longer
    than specified .
    The presence of a tear may have caused the sensor to wrongly identify it
    as indicating the home position.
    Turn off the main power, and check the drive of the intermediate
    transfer belt; then, turn on the main power.
    02xx The period of time between when the home position of the intermediate
    transfer belt is detected and when the next home position is detected is
    shorter than specified .
    The intermediate transfer belt slips on the drive roller, causing a delay in
    the timing at which the home position is detected.
    Turn off the main power, and check the surface of the intermediate
    transfer belt for a tear; then, turn on the main power.
    03xx The detection of the home position of the intermediate transfer belt has
    failed once.
    ITB home position sensor B and ITB home position sensor A must occur
    alternately; however, the same state has been detected continuously.
    ITB HP sensor; then turn on the main power.
    Jun 30, 2010 | Canon imageRUNNER C5800 Copier
    clunking coming from steering cloume left or right turns, car not moving! they say I can lube it, where?
    May 06, 2009 | 2006 Chevrolet Malibu
    The intermediate steering shaft was re-designed to fix that rattle on turns. Not sure if there was a recall for the '05 but seems to me a bunch of guys got it replaced for free. Check out the forums on www.dieselplace.com and do a search for intermediate steering shaft....there is lots of info. You might have to join (free) before you can get search privileges. In any case its a great site for anyone with a D/A.
    Good luck.
    Jan 24, 2009 | 2005 GMC Sierra 2500HD 4WD
    My new RHFE-1004FA has a slight whistle to it.
    May have a bad regulator on the tank or bad gas pressure. The colder it is, the less gas pressure you get out of the tank.
    Nov 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
    Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
    296 people viewed this question
    Top Rinnai Heating & Cooling Experts
    Paul Carew
    vance jones
    Tim Whalen
    Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
