Question about Dakota LY44 Ceramic Utility Heater
I cannot set the thermostat on my Dakota portable heater ?
I do not have the manual can you assist on helping me set the temp on the, DAKOTA DESIGNS 3LY44A Ceramic Heater Power Rating 900/1500 Watts , Model. thanks, Lisa
2 Suggested Answers
  • 249 Answers
SOURCE: 3ly43 dakota multi purpose heater
internel switch
Posted on Nov 27, 2007
1993 dodge dakota 4X4, 185.000miles LX Model 3.9 , runs great had since feb 1993. Problem, very little heat, thermostat has been changed, coolant is good. Takes a very long time to obtain any heat and...
If the vehicle reaches operating temp ( where you normally have good heat ), and the heat is still slack I would suspect your heater core is partially blocked and a backflush would be the place to start. If your vehicle isn't reaching operating temps possibly a thermostat failure, or overcooling issue ( this is why you will see cars / trucks partially blocking radiator flow by means of a cover that's snapped on or some other means)
Jan 21, 2011 | 1993 Dodge Dakota
My truck starts running hot then I turn the heater on and it blows cold air but every once in a while the heater will throw out hot air. Then the temp gauge will go down. I've check med the radiator cap...
I'd still check the thermostat. Or basically just replace it. Have you ever drained all the antifreeze and flushed the system? Good time to do both. If the hose's get real hot that doesn't really mean the thermostat open. Wouldn't they get hot even if the thermostat didnt open.? If the thermostat was stuck open you'd would have cold air and low temp gauge. Then maybe hit a pump or something and have the thermostat stick closed and have high temp. Maybe water pump. Check it when you have the belt off. Spin, pull & push the water pump pulley around. I'd replaced my water pump at about 110,000 on a '97 dodge Dakota. My 97 never had a very good heater. Always heated up more after driving. Idle never got it warmed up.
Jan 14, 2011 | 1999 Dodge Dakota
318 5.2 1998 dakota sport. I have a leak it seems to be coming somewhere on top of water pump can not locate where, also my temp guage doesnot move while running, maybe replace thermostat also no heat....
No heat---replace thermostat and gasket,(it is stuck open)
Water pump--- is leaking,replace,why do you care where it comes from,it is the hole by the bearings
Heater Hoses---Replace
Remove and clean out coolant tank
Flush Power Steering Fluid
Oct 21, 2010 | 1998 Dodge Dakota
1999 dodge dakota blows cold air at idle but heat warms up when revved. would like a solution to this heater problem. I live in alaska and need the heat to function properly. already flushed the heater...
Sounds as if the engine is not building up temp due to cooling system working. If engine temp gage is reading low try covering 1/3 of radiator with a piece of cardboard "Bumper side" to reduce the cooling effect.. just watch temp and out side temps if warming up outside or heavy driving remove the blocking to allow full cooling
Jan 22, 2010 | 1999 Dodge Dakota
My 99 dodge dakota wont heat new thermostat motor
You have a bad heater valve, operated by vaccuum or cable its on the hot water line on its way to the heater core.
Feb 20, 2009 | 1997 Dodge Dakota
Engine does not reach operating temp.
I agree with rpm1998.Is it the engine temp or heater in truck not getting hot enough? If its heater, try backwards flushing heater core.
Feb 05, 2009 | 1997 Dodge Dakota
How do you know if the thermostat is bad on a 1993 dodge dakota
Is the Temp Guage getting hot? If So, it will definately be the Thermostat not working.
Jan 02, 2009 | 1993 Dodge Dakota
Heater control valve
Where is the thermostat in a dodge dakota 1992 located? Flushed it yesterday still just have heat blowinf ti side vents rather cool windsheild defrost. Maybe there is another problem?
Nov 19, 2008 | 1992 Dodge Dakota
98 dodge dakota slt 318. no heat, low operating temp
First thing first, turn off the engine wait for 15 - 20 mints, open the radiator cap and fill it up to the top then start the engine and see if it needs more water adn add as needed, then wait till you ca see the water circulating in the radiator now instead of corculating if it starts boiling out shut the engine replace the thermostat and do the whole thing again.
unless there is water in the engine the gauge will not be able to show the actual temp of the engine, so always malke sure you have water / antifreeze
Nov 15, 2008 | 1998 Dodge Dakota
Dakota LY44 Ceramic Utility Heater Logo
255 people viewed this question
Top Dakota Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you a Dakota Heating and Cooling Expert? Answer questions, earn points and help others
