Question about Breville Die Cast 800ESXL Espresso Machine
Running with power switch off
Hi, all,
As with others who Emailed Fixya, my Breville 800 machine, not in warranty, now turns on when plugged in without pressing the ON button. ..or with the ON button being lit. It seems not to pump water into the heat chamber, but bypasses it down the chute tube into the overflow pan, emptying the machine.
1. What can I do about this problem?
2. Is there an instruction for disassembly? I checked the available screws and can't dope out how it comes apart. ...but if I can open it up, I can at least check valving, relays (if any). ....check PC board, for output voltage, etc.
3. ...may be a programming error, but no reset procedure seems to be provided in the manual. ??
4. If faulty parts are identified, where does one obtain parts?
5. If all above isn't practical or 'iffy', where can I obtain service? ..preferably in the Phoenix area, but can ship if necessary
Thanks for any help you can give me.
Laird Pettit
Phoenix, AZ
    Genius:
  • 1,011 Answers
Sir,
It is like a Electrical Problem. Check with connections and cables. One touch conversion from closed to open mode; the one touch grill dial simplifies the transformation from press mode to Open BBQ with the engagement of an automatic reset feature on return to press mode. Try to change these modes
Thanks
good luck
Posted on Nov 23, 2008
  • 4,472 Answers
Toll Free Phone Number: 1-866-BREVILLE (1-866-273-8455) 8AM to 5PM PST
Email: AskUs@BrevilleUSA.com
The other options are most likely not practical, and definitely iffy. Contact Breville first about service/replacement. If they are unable I will assist you in finding a service location in the Phoenix area. If you still have any questions or need further assistance I will be more then happy to help you further. If you have a moment please accept and rate my solution accordingly.
Thank you,
Lee
Breville making really loud noise when push espresso button
My machine started making a buzzing noise after the cleaning and descaling. It was still under warranty and I was planning to have it fixed by the manufacture but after a couple weeks of using it the noise stopped.
Feb 02, 2014 | Breville The Barista Express BES870XL...
Turns off after heating up once the coffee button has been pressed
Most likely faulty power supply very similar problem to no steam
Be very careful as the powersupply is directly connected to the mains
You can get a replacement capacitor 1.5uf 275VAC from radio Spares online
http://australia.rs-online.com/web/p/polyester-film-capacitors/0148496/
  1. I've had same problem twice
    Once Breville fixed under duress as just out of warranty and no parts
    Last week same problem.
    I tracked problem down to the big yellow 1.5uf 280v capacitor on the power supply board.
    It wasn't passing enough current
    when plugged in the 24volts and 5 volts were OK
    when pressing the On button the Heater relay calls and on light flashes the 24 volt drops to 11volts and the 5v to 4v
  2. Once up to heat the 24 voltage rises to 14v
    when you press the steam button there the 14vis no enough to call the heater relay and the seam light just keeps flashing.
    I replaced the faulty capacitor and all good coffee and steam
Jul 04, 2013 | Breville BES400 Espresso Machine
Any other solutions for screen blackout for acer aspire one?.. id try to use the press hold fn and f2 but its not working at all?..can you help me to fix this problem?..ill wait for your response sir/madam...
Hi and welcome to fixya!
First thing you do for this is shut down the machine by just pressing and holding the power button for about 5 seconds.
Then unplugged the charger and take out the battery.
Next is press and hold the power button again for 10 seconds, without the charger and battery this time.
Put the battery back in and the charger and turn on the machine normally. This should solve the issue 95% of the time. If it does not, time to contact the warranty support for Acer.
Hope this helps!
Takasashi
Jul 19, 2011 | Computers & Internet
Hi, the on off button on my machine is falling can purchase a replace.thankyou tony
Hello Tony,
I understand that you are having a problem with your Breville espresso machines power button. I have located the part for you if you would like to purchase the unit its cost is $5.49 and the site has a blow up of the hole unit that you may want to use to disassemble the unit here is the site http://www.ereplacementparts.com/switch-assembly-power-p-629412.html
Thank you for choosing FixYa.com
Justinbur167
Jun 04, 2011 | Breville Die Cast 800ESXL Espresso Machine
My Breville fresca BES860 cleaning cycle won't start - I hold the three buttons in for 3 seconds and nothing happens. The light has been on for days, and I haven't been able to resolve the issue. Any...
From the model number I guess that you're in Australia? I'd recommend calling Breville themselves on 1300 139798 or speaking to someone at a Breville Service Centre.
Also, is the machine under warranty? I'm pretty sure that's a reasonably new model. Check your receipt and refer to http://www.breville.com.au/care_warranty.asp as it has 12 months warranty.
May 23, 2010 | Breville BES400 Espresso Machine
I've A Breville 800 esxl espresso machine.when making an espressothe machine starts leaking from the external slots outside coffee filter holder.what is the cause of it?
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
May 21, 2010 | Breville Die Cast 800ESXL Espresso Machine
Have a Breville Ikon Panini Press ... doesn't work
First point of call would be to check the microtemp, which is the small heat regulating fuse inside. If that has blown, you most likely will have no power.
Otherwise call you local Breville Service Centre. If you're in Australia you'll find them at http://www.breville.com.au/care_agentsearch.asp
NOTE: In Australia, this model has a Two year product guarantee. Check your receipt as it may be under warranty!
May 19, 2010 | Breville 800 Class 800GR Indoor Grill
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Steam function on the BES400 just stopped working! its been working fine for about 6 months & now the light just continues to blink, no pressure, no steam!
Hi. Did yo fix this? I seem to have the same problem - just started happening today - machine has been working fine for 18 months.
Thanks
Mar 13, 2010 | Breville BES400 Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
23 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
