How to install kaspersky
After opening registry editor what to do for removing avg???actually i have already uninstalled avg but while installng kasper its showing to uninstal avg first...so after opening registry editor wat i have to do further...
  • 10,594 Answers
You need to download AVG removal tool from avg.com and run it to un-install avg anti virus software completely.
Posted on Nov 23, 2008
  • Shahid Electronics
    Shahid Electronics Nov 24, 2008
    It was complete solution and deserve 4 blue diamonds rating.....what do you think?
Why I cannot remove AVG in my laptop? The last time I tried to uninstalled and the process looked not to work so I turned off my laptop. When i tried to remove AVG, it does not work at all. So, I cannot...
If you are facing problem in removing or uninstalling Avg Antivirus from your computer then no need to worry, In this case, the user just need to dial Avg help desk number UK +44-800-756-3354 and make sure that quality form of the technical solution is provided round the clock. http://www.antivirus-helpnumber.com/avg-antivirus.php
Jan 11, 2011 | AVG Download 1-Year AVG Internet Security...
Removal of AVG8
Try bootin to safe mode by pressing F8 on turning on the system then try to uninstall by going into the control panel [Programs(vista)/Add or Remove Programs(XP)]
By doing this you will be able to uninstall the AVG anti virus.
Then restart and the system will boot in normal mode then install Kaspersky. Never have 2 anti virus in a system. Just a word of caution.
Cheers !
Aug 29, 2009 | Acer Aspire 3000 Notebook
My AVG is conflicting with my installing Kaspersky.
you might not have uninstalled AVG .instead you could have deleted the AVG folder.
AVg components are still there in the registry.if you didnt uninstall it ,install AVG once more and uninstall it manually.
if its not working remove AVG components from registry
here are the instrucions:
To remove the AVG registry entries, open Registry Editor (Start-> Run-> Regedit). In the registry editor, navigate to the entries mentioned below,
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\AVG\Avg8
Right click on these entries and then delete them. If you are not comfortable about deleting registry entries, you can use a free registry cleaner. If you are using a 64 bit machine, then these are the entries to be removed.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AVG\Avg8
Once these entries are removed, Kaspersky installation will be completed normally. Alternatively you can also use the AVG cleaner or Kaspersky removal tool for AVG8.
Jul 21, 2009 | Microsoft Windows XP Home Edition
AVG Free Edition wont install on Dell Studio lap top runs Vista
First follow the following steps :
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry:HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\AVGHKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\AVG
  4. Quit Registry Editor.
  5. Restart the computer.
Then uninstall AVG completely from your computer http://computersservicing.blogspot.com/2009/04/download-avg-removal-tool.html
and install AVG free edition.
Jul 11, 2009 | Computers & Internet
Completly Uninstalling AVG8 Free edition
hi..still you might not have deleted some of the
folders,that's why you are not able to install it.
uninstall it completely.
check it out..
thank u..
rate me..
Feb 24, 2009 | Dell Dimension E520 PC Desktop
Can't install kaspersky beacause avg8 not uninstalled
u must have not properly uninstalled AVG properly, remove it from registry also. If you cant do it try any uninstaller software to remove avg completely
Dec 19, 2008 | Computers & Internet
After getting registry editor wat to do?
They easiest and best way to remove AVG is to click on start, click run, type appwiz.cpl and press enter. Find AVG and click uninstall. If you do not have extensive experience with the registry editor I would strongly advice against trying to remove this way. That should be a last resort only and involves more steps than just using regedit.
If the uninstall will not run due to corruption, you may have to download AVG again from http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?tag=mncol&cdlPid=10891365 and install it completely, reboot, then go back through the removal process.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 23, 2008 | Acer Aspire 3000 Notebook
Problem installing kaspersky
open registry editor and delete the registry values belonging to avg... search using keyword avg etc etc and delete them... usually registry is used to find what all software are present..
Regarding installation of kaspersky
It means there are some applications that were not compatible.
It will list the incompatible softwares when after you select to install.
Uninstall them properly.
You have to remove using proper uninstallation tool.
Like even deleting the traces from the registry.
After this you wont be having any problems.
Good Luck.
Live, Love, Laugh.
Sep 09, 2008 | Microsoft Windows XP Professional With...
I can't remove AVG8.0 from my computer
Hi
Thanks for the solution for the removal of the offending avg8 problem. I was immediately able to install the kaspersky program, after deleting the remains of the avg8 program,you guys are great, will contact you again if need be .
Best regards Ian
May 25, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
