Question about Motorola Mobility HS815 Wireless Headset
Pairing to LG Verizon
How do I pair the Motorola H815 to an LG?
I have an LG as well (specifically the Voyager), and I found out how to connect them myself.
Go to the Bluetooth menu in the phone, and select "Add New Device". Hold down the talk button on the headset for about 5 seconds...the light will just be solid blue...then push okay on the phone. It should automatically connect.
Posted on Apr 11, 2009
IHF1000 IS NOT PAIRING SUCCESSFULLY WITH MY VERIZON BLACKBERRY PHONE. I ENTER THE CODE 1-2-3-4 REQUESTED, NOTHING HAPPENS, SO THEN I REPEAT PAIRING STEPS?
yes most motorola blue tooth devices have a pin pairing code of 0000 andyou have to make sure your blue tooth device is in discovery mode.
Feb 25, 2011 | Motorola Radio Communications
I have a verizon motorolo Q phone and a h5500 bluetooth? i do not have passcode. how do I pair it? thank you
Hi, To pair your motorola headset with phone please go to below website.
http://www.motorola.com/mdirect/demos/how2_h500/h500.html
This website shows you video guide how to pair the head set to phone.
ThankYou
Aug 30, 2010 | Motorola Mobility H500 Wireless Headset
H700 MOTOROLA BLUETOOTH WILL NOT WILL NOT PAIR WITH LD SHINE CU720
unfortunately some bluetooth versions are not compatablile and this in turn will not aloow the two to pair or even send and recaive files with each other. try using it with another phone perhaps one on the same network such as att or verizon etc. if it works with no other phone then you may have whats known as a faulty tooth
Dec 17, 2009 | LG Shine KE970 Cellular Phone
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
Feb 06, 2009 | LG VOYAGER VX10000 Cellular Phone
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
Cannot pair LG Voyager cell with Jabra BT150
do you have the bluetooth in discovery mode first before trying to pair?
Nov 30, 2008 | LG VOYAGER VX10000 Cellular Phone
Bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
Blue Tooth Stereo Headphones and KRZR
From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support.
There is no solution
If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine.
I am going to the Verizon store to complain untill i get a different model.
In short the KRZR software is defective
Dec 26, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility HS815 Wireless Headset Logo
183 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
