Question about Price Pfister Home
Soap dispenser pump pricefister
I need instructions for installing a soap dispenser replacement pump on kitchen sink
  • James Feragola
    James Feragola May 11, 2010
    Is there an existing soap dispenser that you are replacing or are you adding one where there was none before?
  • 33 Answers
Here is the link to installing a Price Pfister Soap dispenser:
Soap Dispenser
Hope this helps!
Posted on Dec 05, 2008
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
I have 2 American Standard deck mounted soap dispensers in my kitchen. 1 is for soap and the other is for hand cream. They both worked for a few years, but now neither one pumps. There are no leaks. I have...
All soap dispensers work on a siphon principal. There are o-rings inside these pumps and, over time, they dry out (even when surrounded by soap (which has an acid base)). Unless there is a way to dis-assemble these pumps and replace the o-rings, you may want to start looking for replacements.
Feb 22, 2010 | American Standard Contemporary Kitchen...
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Plugged dispensor of the liquid soap at kitchen sink.
soak it in hot water and try pumping it every so often,should loosen liquid soap.
May 25, 2009 | American Standard Contemporary Kitchen...
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
How do I replace soap dispenser pump mechanism?
Our brand new Avalon model had this problem. It sure appears to be a design defect or defective part. After contacting customer support, they sent a replacement pump (the internal part, not the whole unit).
After removing the unit from your sink, holding the top pull firmly with constant pressure on the pump assembly. It will pop off, but you have to pull pretty hard.
I suggest running water through the top of your unit before putting the new pump assembly on it. Ours had black 'junk' inside even though it was brand new. The new unit just slides on in the reverse process of removing the old one.
Oct 30, 2008 | Price Pfister Marielle Kitchen Faucet with...
Home Logo
490 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
