Question about Apple iBook G4 Mac Notebook
Ibook screen issues
Hi,A G4  12" ibook with screen that comes on but the lower quarter of the screen just stays white (very faint color vertical striping) with a narrow horizontal dark band. The top 3/4 is normal. Then after 2 mins the whole screen fades to dark gray. I close the lid so it sleeps, open again and it will run for another 1 or 2 mins before turning dark gray again.
Should we replace the inverter board, screen, both or something else?
Thanks, TC
  • 11 Answers
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Posted on Nov 26, 2008
Hi I have a 55 inch LCD TV that while I was watching TV it went completely black when I turned it off and the on again there were rainbow vertical lines moving across the screen then at some points there...
My first thought would be to check your TV on multiple inputs to verify that it IS the TV and NOT isolated to your input cable(s). If you can get a solid blue color to come up on the screen by changing inputs then it would really narrow down the issue(s).
Hope this helps.
Jan 04, 2018 | Insignia NSLTDVD26 LCD TV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
FAINT VERTICAL PIN STRIPES MOVINGS TO FULL AREA OF SCREEN
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 16, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Rca 61 inch dlp has vertical lines accross the screen , they come and go by themselves
Hi,If you are experimenting vertical lines ,color distortion,pixilation,or white dots on the screen you might be having an issue with the Dmd chip.This is how the DMD chip works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip is composed of around 2 million pixels that create the image on the screen.You will need to replace in order to fix your problem.Have a blessed one!
Feb 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
Faint blue vertical bars on screen
What you see on your screen are retrace lines, it can happen for various reasons. Jut lower the screen voltage by adjusting the knob specified as "screen" on the LOT, this will disappear.
Jan 27, 2008 | Sharp 32R-S50 32" TV
White lines
not sure but I think this question was regarding a printer?
Dec 28, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Weird TV
the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Oct 06, 2007 | Panasonic CT25G7 25" TV
Apple iBook G4 Mac Notebook Logo
490 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
