Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
IN SINK Erator/ Badger Not Grinding waste
How do I fix my garbage disbosale It is not grinding up sink waste. At this point I have emptied if of an debris. Can you help?
  • 2 more comments
  • Anonymous Dec 27, 2008
    I have one that is about 2 years old, but not exactly sure since I can't find the receipt - so I'm not sure if I'm covered under warranty or not.
    I have the same problem in that the unit is not grinding wastes. It has power, because I can hear the motor humming - I pushed the reset button anyway, but it doesn't do anything. So the motor is humming, but the blades are not turning under power, yet they turn freely when turned by hand or using the emergency wrench (yes, with the power turned off :-).
    I checked their website, and it gives no help whatsoever, other than to call their service center - which I 'm sure that despite whatever they have written there, will end up costing me $.
    If anyone has any suggestions, please pass them along. Thanks.
  • rncmuss Dec 28, 2008
    Hums - doesn't grind. Broom did not work and can't find the restart button.
    same prob
  • Anonymous Mar 29, 2009
    Had the same problem......a guy came in with some kind of "key wrench" and fixed it within seconds.
    Genius:
  • 1,605 Answers
If the InsinkErator is least than 2 years old, you should call the service.
there is 2 year In-Home Parts and Labor Warranty by InSinkErator.
if not you have to disaemble the unit and see what is keeping the blade from turning.
let me know if that is what you need.
Posted on Nov 24, 2008
It will work but it sounds like metal is grinding in it.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Use vacuum cleaner to see if something is loose.
Otherwise, a noisy disposal that works is functional and not dangerous... but annoying.
Life of disposal is probably shortened since the bearing seal could have failed letting water in, and bearings could be rusted.
Replace disposal if noise bother you.
Gene
May 06, 2014 | In-Sink-Erator InSinkErator Badger 3/4-HP...
In Sink Erator leaks half way down
1) Copy following link for troubleshoot and replacement tips.
2) Insinkerator usually has 5 year warranty.
If unit is leaking, then replace with new disposal.
Waste King disposals have longer warranty, but local hardware sells Insinkerator/Badger for less.
Jan 18, 2013 | Electrical Supplies
Leak from area where cord comes out of the in sink erator
Not good seal could be bad are you sure it is not leaking from the top and running down the side.Fill sink all the way then pull plug get a flashlight and examine well.
Apr 17, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My badger 5 plus in sink erator is not working
Here is a tip the I wrote that may help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammedheatman101
Sep 04, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
The blades on my Sinkmaster 550 garbage disposer needs replacing. How do I take it apart and replace the blades?
that is a project I wouldn't reccomend. besides the "blades" are not really changable. The blades are a piece of metal cut at an angle and when they spin they grind the food by rubbing against a series of holes in the base.
if the disposal is not grinding the food, then its time to replace the disposal.
Aug 07, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My waste disposal unit wont turn on
Theres a reset button on the side of the thing.  Also check the breaker box to see if the switch got flipped.
Nov 19, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Stopped up garbage disposal. no grinding action when turned on
Hello there:
you will need to make sure that all of the hoses from the unit are free of debris first ok
than if you need to remove the blade assembly and clean out the area around the unit and than reassemble the blades and see what happnes ok if not you will need to remove the entire unit and see what is making the unit malfunction. ok
best regards michael
Aug 27, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,045 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
