Question about Compaq Presario Notebook
Wireless no longer works
Can't get a wireless connection from my laptop. Quit all of a sudden. can connect if directly connect to modem, but no longer from the router. Diagnoses say I don't have a wireless adapter or that a local cable is not connected. Internet is through HughesNet Satellite, Router is a Belkin
  • harnessedhop Nov 23, 2008
    The only thing listed under network adapters is NVIDIA. No wireless unless this is it. When I checked this, it said it was functioning and updated. If there is no wireless listed, can I still download a driver to reinstall from the compaq site?
  • gm_baller Jan 02, 2009
    i changed my program from xp to vista on an hp 530 and after i chaged it it no longer worked but it worked with xp ??????
    Novelist:
  • 173 Answers
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Posted on Nov 23, 2008
All three were working but 2 of them quit suddenly and say "Check Tel Line". The one that still works is plugged directly into modem. The 2 that say check tel line will work if i plug them into modem just...
This phone system should only have one physical phone jack connection as all the handsets are wireless. It sounds like you may be getting your phone service via your Internet Service Provider. It would help to know how you are connecting your home telephone wiring to your equipment.
Oct 29, 2013 | Uniden DECT1560-3 DECT 6.0 Expandable...
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
Router stopped broadcasting wireless signal
Can you connect directly via cable to the router? If not, the system may be toast.
To make sure everything is clear. Turn off your modem, router and pc. Next power up the modem, the router and the pc in that order.
A possible cause of your problem may be that you had no security on your router and a neighbor mistakenly reset the router to another name or something.
If you find that you can connect to the router directly, I would setup security on the network.
If this helps, please rate me. If you need more help, please write back.
May 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No longer able to connect laptop to the internet with wireless modem. Have had to disconnect and work only from desktop. Have used this for a couple of years and suddenly stopped working. I can see the...
What did you install last on the laptop?, if its anti virus disable it and try connecting.If after that it does not work ,reinstall the computer OS something is corrupted.It's definately not the router issue.
Dec 08, 2009 | Computers & Internet
Dynex Wireless G Router
check the configuration of the router then re-configur the router it
Feb 26, 2009 | Dynex Wireless-G Broadband Router
Internet connection
bring sterlite company of modem. and give last one to repair to nearby computer engineer
Dec 03, 2008 | Alcatel Speed Touch Home Modem
Connecting desktop and laptop to a wireless router
I have the same problem. Startign this morning, when I connect modem directly to desktop, it works. But when I connect modem to this router and then connect to desktop, nothings works.
again - if connect modem back to desktop directly, then it works!.
what is the issue.....? not able to figure it out.
I did reset, change router IP etc etc everything nothing resolves the core issue!
Jul 19, 2008 | Linksys Wireless-G Broadband Router
Router not working
Check the adapter definitions on your PC
Jul 13, 2008 | NetGear WGT624 Wireless Router
Wireless access
my wireless card was working great, then stopped all of a sudden. If I connect to the Modem directly it works, do I need a new wireless card?
Jul 02, 2008 | Toshiba (PA3212U) Wireless Adapter
Wireless
Router is probably configured incorrectly. Try this... Turn off cable modem and router for 1 min. Turn on cable modem...when done booting..turn on router...check for internet. If no...log into router and make sure it is NOT in PPOE but rather in dynamic mode. Good lUck
Sep 10, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Compaq Presario Notebook Logo
457 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
