Question about Vivitar ViviCam 3835 Digital Camera
Memory for vivicam 3835
Im using a 1gig sd card at present and wondered
a,is the camera able to use the whole of the 1g
b,what is the max i can use(would like 2or4gig)
beergut707
  • 79 Answers
SOURCE: SD card for Vivitar ViviCam 4000
hi there
i'm afraid the biggest card you can use on this camera is 512 mb, which should give you about 150 pics at medium quality.
if this was helpful please leave feedback
beergut707
Posted on Oct 19, 2008
  • 3289 Answers
SOURCE: What is the max size of SD card that can be used
Any SD card will work in this camera. The largest capacity card is 2 GB. There are cards that look identical to SD cards that have much larger capacities, but these are SDHC (Secure Digital High Capacity) type cards - not SD cards; an will not work in your camera.
You can download your camera manual here:
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Posted on Sep 26, 2009
  • 102366 Answers
SOURCE: vivitar vivicam 3835.when i try to take a photo
SD and SDHC cards have a slide switch along one edge. The switch needs to be closest to the contacts to enable writing. If it's already there, slide it fully the other way and then back. If this doesn't work, try a different card. If that doesn't work, there may be a problem with the mechanism within the camera.
Posted on Jan 14, 2010
SOURCE: I just bought a Vivitar ViviCam T027 camera. The
Hi there
Funny, I recently bought the exact same model. The answer to your question is simple (that's the good news!)
A long time ago, when these small SD Cards first appeared, they were limited in capacity from 128 Megabytes (MB) to a maximum capacity of 2 Gigabytes (GB).
To enable the same size card to store a greater capacity, a new specification had to be created. This new spec. was SDHC, and allowed the cards to store from 4 GB up to 32 GB.
The confusion arises because people still refer to all these cards as 'SD cards' when the higher capacity cards should really be called 'SDHC' cards.
Your camera will accept standard SDHC cards. Just make sure you don't order 'mini' cards which are much smaller in dimension.
Hope this clears up the confusion.
Phill R
Posted on Oct 19, 2010
Testimonial: "You explained it perfectly. Your right, Vivitar caused the confusion by referring to an SD card rather than an SDHC card. Thanks for your help."
  • 102366 Answers
SOURCE: My ViviCam 8025 always says
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Dec 26, 2010
Camera Vivitar 5388 manual says takes max 1G memory chip. Does that mean anything bigger doesn't work at all. Rob.
It means anything bigger won't work in the ViviCam 5388. They may work in other cameras, depending on the camera.
Jul 19, 2010 | Vivitar Vivicam 5388 Digital Camera
Can i use windows vista with my ipaq 3835 pocket pc and what is till the memory expandable upto
No, you cannot use Windows Vista on your iPAQ.
I am not 100% sure but, I have seen products made before the whole HD SD cards not being able to use them so, I would stick to the regular SD cards which go to 2GB.
Feb 09, 2010 | HP iPAQ H3835 Pocket PC
Just bought a 2 gig SD card and camera keeps
Have you formatted the card in the camera before trying to use it?
Nov 12, 2009 | Vivitar ViviCam 8300s Digital Camera
SD Memory Card
According to the 'ecom cameras ltd' info on this camera the max size of sd card that the X60 will take is 1GB! This may be your problem
Nov 22, 2008 | Vivitar ViviCam X60 Digital Camera
I have a cannon G9 and when using some remote capture software if i try addjust the exposure the camera powers off
What is the Max memory support for Canon S5 IS camera. It supports SD memory, SDHC memory and Multimedia memory card. I wonder what are Multimedia memory cards. Is mini and micro SD cards supported ??
Sep 25, 2008 | Canon Cameras
Memory card
To my knowledge, the Vivitar ViviCam 3315 has an expandable memory by using a Secure Digital (SD) memory card up to 2 Gb as shown here.
As to your other concern, that of the manual, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 08, 2008 | Vivitar ViviCam 3315 Digital Camera
Cameras Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
