Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
No voice - Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
  • mrnevaj May 11, 2010
    No voice in what?
    this could be no voice recording, no sound or no speech in a program.
    Please more detail.
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
Can you help me get a registration code for the speereo voice translator.
Voice Translator keygen
www.cracksinn.com/k/o/o/Speereo™+Voice+Translator/
Speereo™ Voice Translator serial numbers, cracks and keygens are presented here. No registration. The download is free, enjoy.
Download Speereo Voice Translator 4.5 serial number ...
www.cracksinn.com/h/d/r/Speereo+Voice+Translator+4.5/
Speereo Voice Translator 4.5 serial numbers, cracks and keygens are presented here. ... Probably you can find Speereo Voice Translator 4.5 KeyGen here
Speereo Voice Translator for Symbian - SlideShare
www.slideshare.net/olegych76/speereo-voice-translator-for-symbian
Jan 29, 2010 - To do this, launch Speereo Voice Translator and hit 'register' button. ...Your registration code and activation instructions will be sent by e-mail.
speereo voice translator cracked - Google Docs
Jan 11, 2016 | Cell Phones
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
Can not get voice comands
if you mean like "turn right on Madison" as an example, you must have the tts voice selected ...that is the computer generated voices...it will not work with human voices....
go in the system setting and go to the voice option, and see if you have any TTS voices...if not, they may have been deleted..if so, go HERE and download the web updater and 1st see if there are any updates, then after that it will give you an option to add voices...just select one or some that are TTS...after there loaded to your gps, go back in the voice option and change it to one of the TTS voices.
if you mean you have no sound at all, post back and i will help you further.
bill
Jul 07, 2010 | Garmin nuvi 260W GPS Receiver
My gps does not read streets names
To get your TomTom to speak street names, you will need to change the voice from a recorded voice to a computer voice. This can be done by:
  • Connect your TomTom to your computer
  • When the TomTom asks do you want to connect to the computer, choose Yes
  • Open the TomTom Home application
  • Click on the 'Add Traffic, Voices, Safety Cameras, etc.' button
  • Click on the 'Voices' button
  • Click on the 'Computer Voices' button
You can now select a voice to install on the device.
Once you have installed a voice, change it by
  • Disconnect the TomTom from your computer
  • Turn on the TomTom
  • Touch the screen to bring up the menu
  • Touch 'Change Preferences'
  • Touch 'Voice Preferences'
  • Touch 'Change Voice'
  • Use the Left / Right arrows to navigate to the voice you just installed (Look for the word 'computer' in the upper right corner by the male/female option)
  • Touch the 'Select' button
Jan 02, 2009 | Tomtom One XL GPS Receiver
Installing Tomtom voices
You can look in the tomtom voices directory with windows explorer while tomtom is hooked to the pc, be sure the voices files are in the voices directory on tomtom.
Jul 22, 2008 | Tomtom ONE 3rd Edition GPS
Voice recorder
the voice key is on the side of the display screen same side as pwr hold that moz-screenshot.jpgmoz-screenshot-1.jpgto record your voice let go when finished
Feb 21, 2008 | Motorola Mobility RAZR V3
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
