Question about Vtech Lands Phones
Phone not working
VTech 910
I have 3 hand sets. None are working properly. I have checked connections and batteries. All lights on the bases are on. Regardless of what you do, the dial tone is there making calling out impossible. The phones don't ring, either. There are "No low battery" lights on. My touch tone phone does work if that makes any difference.
  • auroragal Nov 23, 2008
    Per response: The phones have been set up for several years. Last night they were fine; this AM the problem occurred.
    Auroragal
    Novelist:
  • 98 Answers
If the VTech is plugged into a different phone outlet than your touch-tone, then I know what your problem is. There are two wires that are hooked up inside the outlet box that run to the jack that your phone cord plugs into. One wire is for the "ring", the other one is for "tip". If these two wires are hooked-up backwards, it will cause you to have a dial tone whether you press any number buttons or not. Don't fret...it's an easy fix. If you pull the cover off of the outlet and reverse the wires meaning that if depending on which two are hooked up to the jack, whether it's the black and yellow pair, or the red and green pair, all you have to do is loosen the two screws that are securing the two wires that are going to the actual jack, and reverse them. Then just tighten the screws back up and replace the cover on your outlet. You should be ready to reach out and touch someone immediately! Hope this helps and have a great day!
Posted on Nov 23, 2008
I replaced the battery and fully charged it. The display says "connecting" then, "place handset in Base to register". It still does not work
possible bad connection base to phone, sharplely take phone on and off base repeatedly, to try and get good contact, ensure contacts(probes) on base are not stuck in or out ,
press the helpful button
VTech Phone User Manuals VTech Cordless Phones
VTech Answering Machine User Manual PDF documents
Feb 04, 2016 | Lands Phones
Battery not Charging
hi :) about battery mayb just a little pro only. u can try to check yr battery charging detect point.i mean the gold colour :) or the charger oso have the gold colour detect point.(it same position detect with yr battery point oso) well,check the both item Point wt i write as above.if it look some dirty ?? juz take some tissue paper clean it up :) Ps: after clean still not work,pls check the charger wyre. good luck :)
Jul 04, 2010 | Vtech Cordless 6041 Phone
Uniden XDECT 7055 hand set problem
Hope this is solved for you. If not, I found the connection for the battery a little temperamental and had to play with it a bit before the connection worked properly
Jul 01, 2010 | Uniden Cordless Phone
One of my vtech 5867 handsets is frozen. It is stuck on one caller id. Battery is charged. What to do?
Have you tried re-establishing connection with the base unit? Try setting it on the base and wait for the charge light to blink a couple of times and re-connect the handset and see if that helps.
Dec 23, 2009 | Vtech 5867 Cordless Phone
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Jan 06, 2009 | Vtech Cordless 6041 Phone
Vtech not working
Have you tried putting in freshly charged batteries and registering the handsets to the base station?
May 01, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
Lands Phones Logo
146 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
