I have a lexmark 4200 and when I try to install on my computer it
Tells me to install module system32.Is this something i have to buy?
could you please help me?
thanks bettye
the valid name of the product is lexmark 4200 series, it is a printer,scanner,fax machine
    President:
  • 1,952 Answers
Most modules are available from CPAN - the Comprehensive Perl Archive Network. They are supplied in what is known as a tarball. A tarball is a gzip compressed tar file. When a module is made the directory structure it lives in is converted to a single file that contains both the files and the directory information. A program called tar performs this function and the resultant file is called a tar file. Tar files have a .tar file extension. This tar file is then compressed using the gzip (GNU Zip) program. Gzipped files have a .gz extension thus a standard module will be called something like:
Some-Module-0.01.tar.gz The first part is the name, the next part the version number and the last part the .tar.gz extension signifying that this is a tarball. You uncompress a tarball using the tar program like this (the $ represents the command prompt):
$ tar -zxvf Some-Module-0.01.tar.gz All *nix systems will have a tar program. On windows you can use CYGWIN which is a set of UNIX tools ported to Win32 to get tar but programs like WinZip will handle extracting tarballs just fine.
One issue with Winzip is that it does not deal well with .tar.tar as an extension. Fix it by changing the extension to tar.gz. Once your have extracted your tarball you then need to make and install your files. You do that like this. At the command prompt navigate your way to the directory created where you extracted the tarball. Making your extractions in a /temp dir is a good idea in case of problems with badly made distributions. There may be several directories to move through. In our hypothetical example above we would expect the tarball to extract into a directory called "Some-Module-0.01", however it may extract to "Some" or even straight into the current working directory (this is not fun to clean up, thus the suggestion of using a /temp dir). Within this module directory we should find a file called "Makefile.PL" although it *may* be several dirs deep. Once you find the Makefile.PL you do the following:
$ perl Makefile.PL
$ make
$ make test
$ make install This should all proceed smoothly and your module should be installed, if not see below. Note on Win32 you will need to use a program called nmake. You can get a copy from M$ here: nmake via FTP or here nmake via HTTP Once you have downloaded it you need to run the program (it self extracts) and make sure that you do this in a directory that is on your PATH. The PATH is a list of directories that Win32 will search for executable files. When you type nmake you want Windows to be able to find the program so it must be in one of the directories on the PATH. To see your current PATH type PATH at the command prompt. C:\WINDOWS or C:\WINNT will be a fairly safe bet.
Now that you have got nmake and extracted it in a directory on your PATH you just do this:
C:\> perl Makefile.PL
C:\> nmake
C:\> nmake test
C:\> nmake install
Ok either everything went fine or you got some errors. Note in the following read nmake for make if your are on Win32
Posted on Nov 23, 2008
  • 790 Answers
Hello!!
Can u be bit more clear in ur query ??
  • Kanth raj
    Kanth raj Nov 23, 2008
    Its an error where some of the dll files are missing. Please reinstall ur drivers!!
Printer say's "please load paper in auto
This could be a printer driver problem. Try to uninstall your existing Lexmark X4270 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark 4200 Series > Tools > Uninstall. After the process, reboot pc when prompted.
Check if your Windows 7 is running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the links below to re-install the printer driver on your computer: - Lexmark X4270 Driver for Microsoft Windows 7 for 32-bit - Lexmark X4270 Driver for Microsoft Windows 7 x64-bit
Jul 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
Trying to install software for x4270 into new machine with Windows 7. Tells me software not available in English. Was previously installed with XP in old machine with no problems. Any ideas?
Uninstall the existing Lexmark X4270 printer driver from your Windows 7 by going the Start menu ? Programs ? Lexmark 4200 Series ? Tools ? Uninstall. Reboot pc when prompted. When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu ? right-click on Computer ? click on Properties. Take note of the system type.
Download and install the X4270 driver for Windows 7 using the links below:
Follow the instructions in the software.
Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have installed the lexmark 4200 program and am trying to get to the fax set up page. I have went ot start, programs but dont see lexmark 4200 series
Computer has to do nothing with fax setup.
Inbound and outbound fax happen through the lexmark device without the help of computer. Computer use the device for the printing purpose only.
All fax related configuration has to be done on the lexmark through the help of its display screen and buttons
Apr 17, 2010 | Lexmark X4270 All-In-One InkJet Printer
Need cd to install lexmark 4200 fax, scanner and printer
try this link..
http://driverscollection.com/?H=4200%20Series&By=Lexmark
OR
http://www.soft32.com/Download/Free/Lexmark_4200_Series/4-176522-1.html
this web page has a Lexmark downloadable driver scanner.
will search your computer for missing drivers - turn fax/printer on first (and have it conected to computer)
Jul 05, 2009 | HP DeskJet 932c InkJet Printer
I HAVE INSTALLED THE LEXMARK 4200 SERIES PROGRAM ON MY COMPUTER THE LEXMARK IS A X4270 MODEL. BUT I AM UNABLE TO PRINT MATERIAL FROM THE COMPUTER TO THE ALL IN ONE LEXMARK OFFLINE OR ONLINE. IS THERE...
START- CONTROL PANEL-PRINTER AND FAXS.
Is it listed there? If not click on ADD A PRINTER, follow the prompts. if that doesn't work , let me know, and we'll try other things. .
Dec 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
I have a wireless system in my home and my lexmark won't print
I have a similar setup - when I installed the printer on my notebook computer, I had to tell the system to look at the computer that actually had the wired connection to the printer, to find the printer.
That is, the printer's attached to my wife's computer, and in the Control Panel of my notebook, it's identified as "Lexmark 4200 Series on JOAN WORK," where JOAN WORK is the name we applied to my wife's computer when we set up the network.
Dec 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4200 all-in-one problem
I got my old printer hooked up last night. THANKS!!!!!!
Sep 10, 2008 | Lexmark X4270 All-In-One InkJet Printer
Installing lexmark 4200 series
If this is for the 4270 follow this link and select your operating. You'll be able to download what you need. If this solves your problem please rate this as fixed. If this is not your printer or you need further help just add a comment and I'll be happy to help you out. Thanks.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X4270
Apr 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4200 printer/fax/scanner
hey buddy its nothing to do with your printer or monitor
but this problem occurs because of your operating system
first try this out
remove all printers from your start > settings > printers & fax
then reinstall your printer ( if you have usb printer remove cable while installing printer and plugin only when it asks )
then try to pring again
if its not printing then no solution buddy
you just have to re install your operating system
only this can help you
Mar 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Installation problems
I LOST CD INSTALL NAME LEXMARK 4200
Jan 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
Alun Cox
David Payne
David Payne
