How to connect cctv over my existing cat5 lan wiring
    President:
  • 2,992 Answers
I just did a Google search for "cctv over cat5" and there were a number of promising links. Here's one as a sample:
http://www.svideo.com/cctvbalun2.html
You should be able to find parts and information you need online.
Posted on Nov 23, 2008
Am having to log in and out or refreshing my pages slow speed freezing lagging
Michael, are you running wired, or wireless connection? With a wireless connection, if other people are accessing the same router, it allocates a percentage of the bandwidth to each device. For example; If your max speed is 100mbps, and you have your smart phone accessing the router, than about 1/2 of the internet is going to the phone connection, and the rest to your system. The more devices attached to the router, the slower it will become. If you are having problems like this and running it "Hard wired" then the issue could be a bad connection between your router and the system. Try swapping out the cat5 line with a new one. These have become really inexpensive now, and I would suggest have 2 or 3 for backups.
10 ft feet Cat5 Cable CAT5E RJ45 LAN Network Ethernet Router Switch Patch...
Nov 02, 2015 | Sony Playstation 3 (PS3) Console
No Internet can I connect to my neighbours so I can watch Netflix on my play station
Hello Friends,
First of all you are self connect to internet, there are two options you are connect internet.
1> Wi-fi through you connect and Lan cable. connection before you configure Internet IP address, DNS to you laptop, and open wi-fi option. and sec option is cat5 and cat 6 wire through connect.
But all thing available you have like RJ 45 connector, Lan tested, Lan cable, cutter, etc.
My suggestion you contact networking engineer because have all network thing available.
More Technical Support visit and call.
Aug 25, 2013 | Computers & Internet
Acer aspire 5335 connects to wireless internet, but not with eathernet cat5 cable?? thanks
Make sure the Network Connection for the LAN is not disabled. Click Start/Control Panel and look for the Network Connections. Make sure the Network Connection for the LAN is not disabled. if it is disabled, right click on it and select enable.
Also the port could be bad on the computer. If it does not light up when you put the cable in the port might be damaged.
May 01, 2012 | Computers & Internet
I bought 1 box of belden cat5e for LAN. when i test it with LAN tester the cables are good but when i connect it to the modem/hub it is not connecting.. please help me.. thanks..
If you've tested the cable and your not getting a link light, there is a posibility that either the port in the switch or the network card is bad.You can try moving the cable to an existing working port on the switch to see if it links up. If not then try another device like a laptop or printer with a NIC card on the cable
Sep 07, 2010 | Belden CAT5e Plenum 4Pair...
Copying CCTV DVR data to external HDD for storing data
use the software that comes with ur dvr. connect to it via lan.. and save the infor in to ur computer
May 15, 2010 | Western Digital Passport WDXML800UE...
NComputing connected to existing Lan network
If your existing LAN has DHCP assigned IP addresses, you will be good to go. If you have statically assigned IP addresses, you will need to enter them in manually into the device. Their website has a very good instructional video on the procedures to hook up the devices. It will work with standard cat5,cat5E, or cat6 wiring.
Apr 29, 2010 | NComputing L230 Network Terminal
How to link with 16 port switch with 8 port switch
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
Apr 03, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Have an AOPEN AX6BC EZ m'board running XP,want to LAN connect
Have you checked in Device manager to ensure your driver is working and that the device is enabled? The driver may need to be upgraded. Most likely the PCI card is not installed with a proper driver.
Also check plugs at both ends of Cat5 cable to make certain all wires are secure. If you added this card then you may have to clear the CMOS and reinstall it. (Be sure to uninstall the cable first.)
Finally, most motherboards today do not have plug n play enabled by default. Go into your set up and see. You are actually better off in some cases with it disabled.
Please write back and let me know how it goes for you.
Oct 11, 2009 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
Alun Cox
David Payne
David Payne
